Thread started 06 May 2010 (Thursday) 23:59
Difference between Auto WB and Custom WB.
fedaykin
May 06, 2010 23:59 |  #1
In this case under tungsten lighting at night, indoors.
Since my XS's WB presets weren't giving a good result for shooting in these conditions(my house) I decided to try out Cutom White Balance. As I don't have an 18% Grey or White card, I had to use house hold paper.
These are my results, ordered as AUTO WB-white reference-Custom WB:
In my kitchen under one tungsten light with AUTO WB
Shot of a white napkin under same lighting in same spot
Same pills on same spot and lighting now using Custom WB
Now I knew I'd get a much better result by setting a Custom WB. But I was still stunned at the difference in tonal range, contrast, etc.
Now I really want one of those little Grey cards. Do you guys have any recommendations? How many of you use Custom WB?
P.S. I can provide another example under similar lighting with a different subject with different reference shot. Thanks for looking.
|Canon EOS Rebel XS(gripped)|Tamron 17-50mm f/2.8(non-VC)|EF 50mm f/1.8 II|EF 85mm f.1.8|Lumopro LP160 flash
My Blog (external link)
tonylong
...winded
Gallery: 60 photos
May 07, 2010 00:21 |  #2
Well, one technique that has been put out is to use a white paper coffee filter over your lens. Switch to MF, take the shot and it becomes your target for either a custom WB or, if you shoot Raw, your reference shot for quick WB adjustment.
Tony
fedaykin
May 07, 2010 00:28 |  #3
tonylong wrote in post #10136717 (external link)
Hmm, should try that too. Though I imagine in that case I'd have to point the camera toward the light source right?
tonylong
...winded
Gallery: 60 photos
May 07, 2010 00:38 |  #4
fedaykin wrote in post #10136743 (external link)
No, just point it into the scene -- the filter collects and diffuses the ambient light. It's worth a try. For a lot of indoor/artificial light situations, WB is a "best guess" on the part of the camera, so you do your best.
Tony
fedaykin
May 07, 2010 00:42 |  #5
tonylong wrote in post #10136768 (external link)
Haha I just saw a DIY project someone did where he cut out a round piece of coffee filter and placed it inside a UV filter to use as an Expodisc of sorts. Seems like a good idea.
mike_d
May 07, 2010 01:06 |  #6
Why does it seem that incandescent light is so hard for AWB to handle? AWB does a decent job in many other situations but misses by a mile under a century old lighing technology.
fedaykin
May 07, 2010 01:15 |  #7
mike_d wrote in post #10136842 (external link)
I've thought about this myself, would like to know as well.
zozoka
May 07, 2010 02:04 |  #8
Good idea for quick raw white reference
5D ; 30D ; 17-40 4L ; 24-105 4L ; 70-200 4L ; 50 1.4 ; Tamron 200-500 ; 430EX
RichSoansPhotos
May 07, 2010 02:51 |  #9
Thank goodness I shoot RAW, I don't need to bother about this, lol
Gatorboy
May 07, 2010 05:51 |  #10
Did you try setting your WB to tungsten?
Dave Hoffmann
neilwood32
May 07, 2010 06:44 |  #11
It might be due to the cyclical nature of incandescent lighting. As it runs at mains voltage, the lights are actually flickering due to the frequency cycle (50hz in the uk, 60 in US IIRC). Its imperceptible to the human eye which has approx a 25hz refresh (not sure what the correct term is ). As the camera will sample the light in an instant (way less than the 0.02secs of the cycle), it will inevitably miss part of the cycle and hence the WB will be off.
This is also the reason that at certain shutter speeds in gyms and other indoor shoots you get inconsistent exposure across a frame (green or yellow tint at one side)
RAW is of course the easiest solution as you can adjust the WB yourself to suit.
Incandescent is a setting which takes account of the cycling (and doesnt sample the light conditions) therefore giving more consistnt results.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
tracknut
Joined Jun 2005
May 07, 2010 10:08 |  #12
I use CWB all the time, the exact way you did it. A nice white sheet of paper. I just can't imagine that a "special" piece of something white would be all that much better.
Dave
Performance/sport dog photographer (external link)
Facebook (external link)
"Always available to shoot your dog"
fedaykin
May 07, 2010 12:05 |  #13
Gatorboy wrote in post #10137404 (external link)
yes, and it came out almost exactly like the Auto WB setting.
neilwood32 wrote in post #10137521 (external link)
Thanks, I didn't know that.
tracknut wrote in post #10138394 (external link)
I'm considering getting a white card or something but mainly for the portability.
Question Do you guys have a preferred way of adjusting WB in post process? Auto correction, stretch contrast? Using levels, curves?
tracknut
Joined Jun 2005
May 07, 2010 12:42 |  #14
In my case, I try to get it right in camera, but if it's off I generally use the white balance selector in curves to adjust.
Dave
robscomputer
May 07, 2010 12:44 as a reply to  @ fedaykin's post |  #15
In most cases when I'm taking casual photos I'll use auto white balance, it's just easier to have the camera decide and in 95% of the time, it's near spot on.
When I'm taking formal photos for a friend, like engagement photos that can't redone easily and need to be right proper, I'll use custom white balance using either a gray card or Expodisc. I can adjust in post but it's so much easier to have all of the photos already done even before I down load them.
Amateur photographer
2,726 views & 0 likes for this thread, 10 members have posted to it.
2875 guests, 180 members online
