Thread started 08 May 2010 (Saturday) 07:13
70-200 f/4L IS date code UY with dust inside
match14
May 08, 2010 07:13 |  #1
I have a 70-200 f/4L IS with a date code UY, which I'm sure is 2010, which I have had since March 2010. I have recently noticed dust on the inside of this lens and wondered if this is normal since this lens is supposed to be resistant to dust and moisture. I do not have a filter fitted to it so I'm not sure if that one is required to make the dust sealing complete, the lens manual does not state that a filter is required. Can any one else with this lens please advise me if they have dust in there copy?
On a side note I do appreciated that dust resistant is not the same as dust proof and that dust inside a lens does not affect image quality, I'm just wondering what other users of this lens thoughts are?
David
500px (external link)
Gear
timnosenzo
May 08, 2010 07:46 |  #2
It's really only dust and moisture resistant with the rear cap on, or when it's mounted to a body. If there's dust in the body, it can transfer into the lens, or you can pick up dust when you have the rear cap off.
This lens does not need a filter to complete the weather seal.
match14
May 08, 2010 13:09 |  #3
I guess if you don't have a sealed body like the 450D/XSI then the lens is not really sealed at all?
David
Gear
Big ­ Stick
May 08, 2010 13:12 |  #4
Debris will always take the path of least resistance...........
flexthatdx
Jun 05, 2010 12:08 |  #5
take apart the front element and clean it
2,620 views & 0 likes for this thread, 4 members have posted to it.
915 guests, 118 members online
