Thread started 08 May 2010 (Saturday) 10:29
Tasty...
gking
May 08, 2010 10:29 |  #1
This is our kitten Gandalf showing his great eyes and licking motion.
I would love to hear from you about improving the photo.
Canon EOS Digital Rebel XTi ; Canon EOS 650 35mm; Canon Zoom Lens EF-S 18-55mm 58mm -1:3.5-5.6 II; Canon EF 70-210mm 1:4; Canon EF 50mm1:1.8; Canon EF 28mm; Sigma 70-300 APO DG Macro; Canon Speedlite 420 EX
JoYork
May 08, 2010 10:34 |  #2
It's pretty good as it is. I think you did a good job under the circumstances.
For better results try to get somewhere where there's better light - the lighting on the cat is fairly even and as such looks quite flat and dull. That's easier said than done, of course - cats go where they want to unless you trick them :)
Did you fire the flash from the camera? You might want to try bouncing the flash off a nearby white wall, that will add some three-dimensionality to the image.
Jo
gking
May 08, 2010 10:48 |  #3
As you know, cats will pose only if they want to... I got him with a window with blinds on his back and his left side. Very sunny day.
I used shutter 1/60s, Aperture f/5.6, ISO 400 (probably too high), used flash and red eye on, focal at 55mm.
I agree, my flash should not go on with so much light around, but it did.
Thanks for the comments.
JoYork
May 08, 2010 11:25 |  #4
I think you definitely needed some flash, but the hard bit is trying to get away from the on-camera flash look. He's a lovely looking cat, I miss not having ours around.
Jo
juxtagirl
May 08, 2010 12:49 |  #5
It has a gray cast to it that can be helped in PP. It would make a huge difference to do a curves or levels adjustment.
Canon EOS 5D Mark II Gripped :: Canon EOS 30D :: 24-105mm f/4L IS USM :: 50mm f/1.8 :: 100mm f/2.8L Macro IS :: 3 B800's :: ABR800 w/ moon unit :: AB 42" PLM v1:: AB 86" white PLM v2 :: AB 64" silver PLM v2 :: 32x40 AB Softbox :: AB White Beauty Dish :: Metz 48AF-1 :: and a pretty Cheeky Lime bag :)
PhotoCupcake
May 08, 2010 12:57 |  #6
juxtagirl wrote in post #10144640 (external link)
This.
Up the contrast and see if you can't improve the white balance.
gking
May 08, 2010 13:03 as a reply to  @ PhotoCupcake's post |  #7
Used the curves... how is it?
1,635 views & 0 likes for this thread, 4 members have posted to it.
Tasty...
649 guests, 120 members online
