Hi to all, I would like to sharing this link with you and want to know if some vary else had been trite this calculator distance,
http://www.lensalign.com/ldt/index.html![]()
Geo Goldmember 1,690 posts Joined Nov 2006 Location: Miami Springs, FL. More info | May 09, 2010 10:37 | #1 Hi to all, I would like to sharing this link with you and want to know if some vary else had been trite this calculator distance, flickr
IslandCrow Senior Member 589 posts Likes: 1 Joined Oct 2008 Location: Rapid City, SD More info | May 10, 2010 12:19 | #2 Thanks for the link. Canon recommends 50x the focal length of the lens (I'm not sure if this changes for full vs. cropped sensors), so a 50mm lens should be 2500mm (or 2.5 meters) away from the object you're focusing on. It seems like this calculator comes up with about half the distance, but I certainly couldn't say which is better to use.
May 18, 2010 08:18 | #3 IslandCrow wrote in post #10154640 Thanks for the link. Canon recommends 50x the focal length of the lens (I'm not sure if this changes for full vs. cropped sensors), so a 50mm lens should be 2500mm (or 2.5 meters) away from the object you're focusing on. It seems like this calculator comes up with about half the distance, but I certainly couldn't say which is better to use. Thank for you comment, I think that it make a great job, Chuck Westfall had been spoked about it and he say that it hardware do a great job. flickr
| Latest registered member was a spammer, and banned as such! 2755 guests, 174 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
