I think that many have been told about the Eos 7D performance...even if its about IQ or even about the multicomplex AF system...
so let me tell you my point of view about this well hiding little beast...
its been a month that came into my hands and started to play with it...not every day due to personal reasons but very often...
Coming from the ''old'' Eos 1 Mark 2n school and from the 40d i wasnt really familiar as many of you here i believe with thisweird AF system...
At first shots i was really satisfied about the overall performance in colour light metering ect...so whats left..?? Lets test the AF...
As all of you the test shots i took in real world and af charts were Soooo Many....(most of thme were INDOORS) and the combination is a killer one...with ''the brick'' 24-70 L on it i wasnt afraid of anything...
Shot per shot and time after time the tests in the AF system and the sharpness of the combination were all against the 7D and the 24-70 L ...GUILTY AS THE COURT SAID....
Something wasnt ok...it seems the combination was in great need of Microadjustment...i put the number of MA in plus 12..(+12) as it seemed the correct number... then something more weird happened...in straight horizontal position all shot were OOF....but in diagonal down position at 50 degrees height lets say the shots were all CLEAR... (this happened cause the Super Sensitive af system was focusing closer to me if i was a bit lower...35 deggres istead of 45...AND I THOUGHT IT WAS FRONT FOCUSING..thats why i MA at +12....but in straight horizontal position it was really back focusing because i had the +12..!!!!:o )
so more tests were on schedule.....so after so many more test again i was in the correct conclusion finally...!!!
I WAS the guilty one...not the 7D...i was made mistakes that led me to the false conclusions...so i put again in the default number 0 the MA and all my shots are great now..
USER ERROR is the right conclusion...
why???? xmmmmmmmmm...
first of all is that we can't do indoor Sharpness tests and be satisfied...you can see all that in outdoor shots sharpness is much more obvious than inside... (check here for examples.. https://photography-on-the.net/forum/showthread.php?t=760327 ) this can lead to false idea about the sharpness.... so...test the camera IN BRIGHT SUN..thats the way to be 100% sure....And if you see that in bright sun the shots are Oof then YES you can worry about microadjustments or return it to CANON...
I Saw many shots with low shutter speeds and the users complained about OOF shots...thats normal...what did you expect..?????
I Saw many great shots in the gallery...so many that all you guys should be proud...i was worried and i was soooo wrong..
I strongly believe that in many cases about the complains that have heard about the 7d are mostly due to USER ERROR...
like mine false conserns...(it needs precise focus to be correct...its not like the oldest AF systems that we are all used to!!!!)
My camera now is in the default settings in the Microadjustment settings...
but i did the folowing from the Custom Functions...
1. I turned off the noise reduction...
2. I stopped the continue AF when af is impossible..
And iam finally happy.. and enjoy my tack sharp as hell photos..!!
better than my eos 1d mark 2 and my 40d...!!
thats a point from me...only an opinion...
thank you for your time and please excuse me for any language mistakes in grammar or spelling..!!! I am from Greece..~!!
Please feel free to share your experiences with the EOS 7D...!!!
