petris wrote in post #10184626
I have Skin-set and i use part of it with StreetwalkerHD. I changed backback original belt to Pro belt.
Normally i use Skin Chimp Cage and Skin 75 Pop Down, take what i really need and leave another in backbag. Often i leave even backback in a car or hotel.
Skin pouches doesn't have protective material, but it's not a problem, lightweight is better.
I don't use too often DW, it's so large and i am so large that i can't go easily down with all stuff
How'd you find the Skin 75 PD? Does it flop about a lot when there's a lens + hood in place inside?
Unless I get a buyer for the DW from the skin set, I guess I'll just buy the components I need separately... Too bad about saving money I guess.
kinghong1970 wrote in post #10184776
if i remember correctly, the TT Shapeshifter's unique ability to collapse flat is because it has generous elastic pockets inside (that are not padded) and lays flat when empty.
you may have some difficulty insserting a padded lens case inside the elastic pockets.
also, when you stretch any elastic fabric too much, it will not recover to the original shape...
Ah, I'm not intending to put any modular pouches inside. The elastic pockets are neoprene so they're pretty 'padded' in a sense, slowing down what's packed inside of them in the case of a bag drop. Physics: momentum and all that jazz.
Btw I can fit my think tank steroid speed belt on the shapeshifter but it's not an ideal fit - the bum-padding flap's velcro isn't catching more than half of the bag's bottom velcro... is this dangerous? Need I shift to a pro-speed belt instead?
