Thread started 11 May 2010 (Tuesday) 09:49
7D focusing question
tolyD
May 11, 2010 09:49 |  #1
I have new 7D with 28-135 kit lens. When im shooting in AFlive mode, im achieving much sharper focus then in any regular modes using a single point AF, is this normal??? I think there is something wrong here. please help.
5D MkII | 35L | 50 1.4 | 85 1.8 | 2x 580ex II |
flick (external link)r
web (external link)
facebook (external link)
bsmotril
Gallery: 11 photos
Joined Feb 2006
May 11, 2010 10:34 |  #2
Single shot or servo focus mode?
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
jwcdds
Gallery: 1924 photos
Best ofs: 8
Joined Aug 2004
May 11, 2010 10:35 |  #3
Well, if your Live View gets you sharper photos (assuming you're not using "P" mode), then it's possible that your lens needs micro focus adjustment. Live View focus is based on contrast detection on what the sensor sees. Normal focus is via the AF sensor so it could be your lens, or even possibly your 7D. But won't know until you have more than 1 lens to test.
This isn't your first DSLR, is it?
Julian
krb
May 11, 2010 10:38 |  #4
I assume you mean to say that when you are in live view and use that AF it is more accurate than the normal focus in the viewfinder. The focus mechanism in live view is not only more accurate but it is able to work at smaller apertures. The downside is that it is so very, very slow.
They shouldn't be too far apart in accuracy and this may indicate that you need to use the auto focus microadjust to calibrate the focus with that lens.
-- Ken
Gear list
tolyD
May 11, 2010 10:44 |  #5
bsmotril wrote in post #10160884 (external link)
im using single shot
web (external link)
tolyD
May 11, 2010 10:45 |  #6
jwcdds wrote in post #10160891 (external link)
i have tried every mode where I can use a single point and i get the same problem.
web (external link)
pknight
Gallery: 39 photos
Joined Feb 2006
May 11, 2010 10:48 as a reply to  @ tolyD's post |  #7
If your lens needs microadjustment, it won't make any difference what mode you are in. Try the suggestion of microadjusting the lens.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
tolyD
May 11, 2010 10:48 |  #8
krb wrote in post #10160907 (external link)
yeah i does takes a bit longer to focus in live view but using viewfinder it seems to be soft and OOF. How do i calibrate, is this something i can do on my own or do i have to send it in?
Everyone thanks for helping.
web (external link)
tolyD
May 11, 2010 10:50 |  #9
pknight wrote in post #10160958 (external link)
is this something that I can do on my own??
web (external link)
pknight
Gallery: 39 photos
Joined Feb 2006
May 11, 2010 10:51 as a reply to  @ tolyD's post |  #10
You can do it yourself with the 7D. It is explained, somewhat, in the manual. Search here for microadjustment and you will find lots of advice on how to do it.
krb
May 11, 2010 10:53 |  #11
It's an option in the custom function menu for autofocus. You can also search this forum for the term "MAF" for discussions of how and what.
IMO, you should:
1. Use MAF to confirm that there is a calibration issue.
2. Borrow another lens from somebody and take some test shots with it to see if it is accurate or if it needs calibration too. This will help you identify whether it is the camera or the lens that is not calibrated correctly.
3. Once you have an idea of which item is not calibrated, send it to Canon for repair under warranty.
The calibration needs to be set at different focal lengths and different focus distances and the MAF in the camera doesn't allow that level of control. Better to tell Canon to make it work the way it is supposed to.
-- Ken
Gear list
jwcdds
Best ofs: 8
Joined Aug 2004
May 11, 2010 10:53 |  #12
Yes, the 7D allows you to make adjustments to each lens. It's in your custom functions and you can register up to 20 separate lenses for adjustments. That said, it can only compensate for -20/+20 so if your lens falls beyond that range, then something's off. It's possible, though usually less likely that it's the camera body that's off, but you'll need to have more than 1 lens to prove that.
I think it's time to break open that vacuum-sealed manual and read through it.
Julian
pknight
Gallery: 39 photos
Joined Feb 2006
May 11, 2010 10:54 as a reply to  @ pknight's post |  #13
See the second message in this thread:
https://photography-on-the.net/forum/showthre​ad.php?t=862834
tolyD
May 11, 2010 12:04 |  #14
krb wrote in post #10160990 (external link)
IMO, you should:
I've shot my brothers wedding with 17-55 f2.8 canon rental over the weekend and they seem to be good pictures in focus. so now i've placed my lens back on since i have returned the rental and noticed how unsharp it is. In live view its actually pretty sharp for 28-135 lens. Its upseting to discover a problem like this for the price.
Seems like its a very common problem with these lenses or cameras. what makes it worse is that a lot of users are not even aware of this. Makes me very disappointed when i spent so much money for something that is suppose to be so great and it turns out NOT to be. I don't understand one thing, how can Canon allow these issues to so many costumers with their lenses or whatever is causing that focusing problem?? Im losing trust in Canon after spending so much money. Its like buying a new car with terrible alignment.
web (external link)
jwcdds
Best ofs: 8
Joined Aug 2004
May 11, 2010 12:15 |  #15
Meh. I certainly am not defending Canon but this is just the nature of electronics. Besides, we don't know if it's the 7D or if it's the 28-135. microadjusting lenses isn't difficult. But if you don't want to be bothered with it, then return it to the store.
Julian
6,811 views & 0 likes for this thread, 15 members have posted to it.
1281 guests, 121 members online
