Thread started 11 May 2010 (Tuesday) 14:49
upsizing picture with text for white house
psxindo
May 11, 2010 14:49 |  #1
I want to print 24 x 36 from white house.
They need the files to be @ 300ppi
That means 7200 X 10800 pixels
But my camera can only produce approximately 3647 x 5469 pixels.
I'm planning to add text as well.
I can only manage to get 11x16 @ 300ppi picture.
Should I upsize the completed poster (picture + text) to 24x36 @ 300ppi
or
Should I upsize just the picture and fit it into 24 x 36 @300ppi canvas size and then add the text ?
What is the best way to make the 24 x 36 print?
Thanks in advance
5D mkIII | 5D mkII | 6D | EOS M | 16-35L | 24-70L | 70-200L 2.8 IS mkII | EF-M 22 | 50 1.4 | 85L | 100 2.8 macro | Tamron 17-50 2.8 | 2x 580 ex II | 580 ex | 2x sunpak 383 | 134GB CF |
Wishlist | 14L | 24L | 35L | 50L | 100L macro | 135L | 15 2.8 FE | 17L 4 TS | 45 2.8 TS | 90 2.8 TS |
kirkt
May 11, 2010 15:09 |  #2
If you are using a lab to do your print, let them upres the final - as long as you submit a file to them that fulfills their requirements for a 24x36 you should be good to go. Otherwise, I use Genuine Fractals.
Kirk
Attached are 100% crops of 72 point text on
1) a document of the pixel dimensions at 300 ppi that you stated above (3647 x 5469)
2) an upres'ed image of same at 100% (using Genuine Fractals) so that the doc is 36x24 @300 ppi.
If the lab's upresing is any good, it looks like crisp text won't get crushed - the upres was 200% to get your original camera dimensions up to the final.
Kirk
Jeff ­ Colburn
May 11, 2010 15:10 |  #3
I'm not sure about upsizing the image, but I would add the text after you upsize it. I just find adding text last is the easiest for me.
Have Fun,
Jeff
If you're interested in photography, stock images of Arizona and Fine Art Prints of Arizona, visit www.JeffColburn.com (external link)
Damo77
May 11, 2010 17:17 |  #4
As long as your text remains a text layer (ie you don't rasterize or flatten it), it doesn't matter if you upsize the image afterwards. The text will remain a vector, and is therefore infinitely resizable.
Damien
Website (external link) | Facebook (external link)
tim
Light Bringer
May 11, 2010 17:45 |  #5
https://photography-on-the.net …/showthread.php​?p=3740438
Text last.
psxindo
May 12, 2010 01:22 |  #6
Thanks guys.
Thanks Tim, that was very usefull
1,191 views & 0 likes for this thread
Latest registered member is AlexRapp
1216 guests, 268 members online
