Hi there...
What should be the DPI for files for printing? 300dpi?
for printing 4x6's and/or 8x10's..?
Thanks,
Theresa
PhotosByT Member 222 posts Joined Mar 2010 Location: Ontario, Canada More info | May 11, 2010 21:30 | #1 Hi there...
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2010 21:57 | #2 Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | May 11, 2010 22:00 | #3 |
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | May 12, 2010 09:58 | #4 Damo77 wrote in post #10164916 That's a question best answered by your lab. Theresa- Are you printing yourself or sending out to a lab? Chas P
May 12, 2010 11:05 | #5 ChasP505 wrote in post #10167113 Theresa- Are you printing yourself or sending out to a lab? sending to a lab, thanks! I'm just actually getting started with doing photography for pay
May 13, 2010 06:43 | #6 The most important thing is to get the aspect ratio correct. Your camera shoots with a 3:2 ratio (width:height). 6x4 is the same ratio but 10x8, isn't so the image would need to be cropped to fit. Frank Hollis - Retired mass spectroscopist
May 13, 2010 18:47 | #7 hollis_f wrote in post #10172798 The most important thing is to get the aspect ratio correct. Your camera shoots with a 3:2 ratio (width:height). 6x4 is the same ratio but 10x8, isn't so the image would need to be cropped to fit. Yes, I do get the ratio.. I crop to the proper size.. but what dpi should it be set to? 300 is usually the norm if you print on your own printer.. but how about if I send to say Costco or others?
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 13, 2010 19:09 | #8 300. If you print yourself 300ppi is probably fine, but the dpi will be closer to 4000. Go have another read of the printing FAQ I already linked to Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | May 13, 2010 21:37 | #9 There will be suggestions on the websites of any lab you use. Costco, WHCC, Nations... they all give you an idea of what they want to see when you send the files. But 300 is a good average.
May 14, 2010 02:41 | #10 PhotosByT wrote in post #10176434 Yes, I do get the ratio.. I crop to the proper size.. but what dpi should it be set to? 300 is usually the norm if you print on your own printer.. but how about if I send to say Costco or others? Ignore it. Crop your image to the correct ratio and send the file as-is. When Costco print it they'll use the full sized image - giving you the highest possible ppi value for that image. Frank Hollis - Retired mass spectroscopist
| Latest registered member is semonsters 1059 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
