Thread started 13 May 2010 (Thursday) 10:06
7D wireless flash question
kevlarrr
May 13, 2010 10:06 |  #1
Hi, I'm currently using my 7D's wireless feature to trigger my 430ex. It works fine but the only down side is that if I continuously keep shooting, after a while, I get the "busy" indicator between shots. Reason being, the on camera flash might be getting over worked as its needed to flash each time I trigger the remote 430ex.
So is there a work around for this issue. I tried setting the on camera flash to manual and set it to lowest power but it didnt help. I cant affor the pocketwizards right now so I guess I'll have to continue using my cord for OCF :(
Any other solution would be great...
Thanks,
Kevin
My Gear: Canon 7D, 70-200L f/2.8 IS II, 17-40 L f/4, 30 f/1.4, Flashpoint II 320m, 430EX II, YN-460 II, RF-602
msowsun
"approx 8mm"
Gallery: 18 photos
May 13, 2010 12:04 |  #2
Are you using the built in flash to add light to the scene or just triggering the external flash?
In the 7D flash menu, the Wireless func. has 4 options:
1) Disable
2) external : built in (Ratio)
3) external only
4) external + built in (added together)
I would expect that choosing option 3 should use the least power from the built in flash and give you faster recycle times.
kevlarrr
May 13, 2010 12:12 |  #3
msowsun wrote in post #10174289 (external link)
1) Disable
3) external only
Yes im using the built in flash just for triggering the external and doing this using option 3 you've stated above...so I guess nothing more can be done? :(
Thanks for replying!
Gometang
May 13, 2010 12:20 |  #4
Just scratched what I wrote because I didn't read carefully lol. Buy the ebay triggers for 50-60 bucks :) They work great.
kevlarrr
May 13, 2010 12:41 |  #5
Gometang wrote in post #10174375 (external link)
What are they called? Can I have a link :)
msowsun
"approx 8mm"
Gallery: 18 photos
May 13, 2010 13:10 |  #6
ebay triggers are manual mode ony. (No ETTL)
http://photography.sho​p.ebay.ca …3286.c0.m14&_so​p=15&_sc=1 (external link)
Gometang
May 13, 2010 13:40 |  #7
kevlarrr wrote in post #10174488 (external link)
Just search for Yongnuo RF-602.
kevlarrr
May 13, 2010 16:06 |  #8
msowsun wrote in post #10174663 (external link)
http://photography.sho​p.ebay.ca …&_trksid=p3286.​m270.l1313 (external link)
Im trying to shoot manual anyway, so I guess NO ETTL should not be a problem.
Gometang wrote in post #10174823 (external link)
Thanks!
May 13, 2010 19:27 |  #9
yongnuo is a decent product I have a couple.. and they work really well.. I tested on my 7d and xsi and work at over 80 ft 100% actuation on all 3 I have. also comes with a camera lead for remote shooting.. wireless actuation.. if you don't already have that.. just be sure to order the right model and be ready to wait a couple of weeks.. it ships from China.
Body: Canon 7d - gripped | Canon Xsi - gripped |
Glass: 16-35 f 2.8L | 24-70 f2.8L | 70-200 f2.8L| 100 F2.8 L Macro| 50mm f/1.2L|for sale 50mm f 1.4
Flash: 580EX II (x2) | Battery Pack CP-E4
www.MaltesePhotography​.com (external link)
kevlarrr
May 13, 2010 21:52 |  #10
007 wrote in post #10176623 (external link)
I just ordered the RF602 from here (external link) but it doesnt say it works for the 7D (Canon 1D/1DS, EOS 5D Mark II/5D/50D/40D/30D/20D/​10D)....this makes me nervous now :(
4walls
Joined Jan 2004
May 13, 2010 22:11 |  #11
I just purchased a RF602/C YONG NUO Wireless Flash Trigger while on a trip to Hong Kong. I tried it out in the store on my 7D and 430EX and it works flawlessly.
As a bonus, it came with a PC Sync cord and I can plug it into the Remote jack of the 7D and fire the shutter using the transmitter. I have been playing with it a little and it seems to work very well so far.
You may ask why I need one of these with the 430EX, well I was attempting to hack the flash using instructions similar to these (external link) and I think I damaged the SLAVE/OFF switch. So the wireless function on my flash does not work natively with the 7D.
kevlarrr
May 14, 2010 00:45 |  #12
4walls wrote in post #10177423 (external link)
Sounds like RF602 is a pretty decent trigger...thanks
4walls
Joined Jan 2004
May 14, 2010 01:21 |  #13
The Big drawback is no eTTL. It is manual exposure all the way.
2,253 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is ahmed0essam
1553 guests, 188 members online
