Thread started 14 May 2010 (Friday) 21:16
Flash Not Firing with 5DMarkII
ekrizo
May 14, 2010 21:16 |  #1
I am not sure what forum to post this in, so please move this if you think it fits better elsewhere...
I recently upgraded from a 40D to a 5DMark II and have noticed that a significant portion of the time, my 580EXII Flash is not firing properly when on my 5DMarkII.
Here is my setup: The 580EXII is connected via a hot shoe cable(OC3) in ETTL mode (which worked with my 40d) and seems to recognize that it is connected as it shows the distance reading, zooms with the camera, and the pilot light is on. It seems like if I focus on something close (i.e 5-8 feet away) it will not fire. If I focus on something a little further (~10feet) and am zoomed in, it will flash, but if I zoom all the way out it will not flash.
I was just wondering if anyone else has experienced this and or if perhaps I am doing something wrong.
Thanks!
Erin
mmahoney
May 14, 2010 21:30 |  #2
Does it work OK without using the off-camera cord?
Newfoundland Wedding Photographer (external link)
ekrizo
May 14, 2010 21:36 |  #3
Well, you know, I thought I had tried that, but I guess not... It works fine when mounted directly without the flash cord.
windpig
Chopped liver
May 14, 2010 22:36 |  #4
OCF chords can be problematic, very frustrating. What OCF chord do you have, Canon, aftermarket?
Go ahead, spin the wheel.
ekrizo
May 15, 2010 05:01 |  #5
It is a Canon. I have it mounted to a Flash Bracket, so perhaps it has gotten stressed due to that? I am just glad to know there isn't something wrong with my 5DMII!
Hermes
May 15, 2010 05:10 |  #6
You'll probably find that the screws that hold the shoe together have come loose - It's a common problem with the canon cord. Tighten them up again (using a bit of loctite will help) and there's a good chance that will solve it.
mmahoney
May 15, 2010 05:59 |  #7
ekrizo wrote in post #10184487 (external link)
Keep an eye on things .. the Canon cords are known to break off at the flash mount with very little pressure, when this happens your flash can hit the ground!
I've had better success with Yongnuo cords .. reliable and I've not broken one yet.
windpig
Chopped liver
May 15, 2010 07:56 |  #8
mmahoney wrote in post #10184597 (external link)
I had a yongnuo cord break the first time I attached a flash to it.The screws used were to short and didn't go completely into the base portion.
PixelMagic
May 15, 2010 08:20 |  #9
The Promaster cord is considered to be much more robust than Canon's.
As recommended by Arthur Morris:http://www.birdsasart.​com/accs.html (external link)
Once again Robert O’Toole’s vast technical knowledge saved the day. He suggested using the remote cord that he uses, the PROMASTER “Flash Extension Cord/Off Camera TTL unit. He stated that he had been using one for two years without a single problem. It took me a few weeks to get my hands on one, and several months more to order 100 units. I have been using mine for more than three months and am impressed with the sturdy construction and the performance. Full automatic flash exposure control is maintained with all modern Canon flashes.
karobinson
Sep 20, 2010 18:51 |  #10
I have had to replace two ETTL cords already in less then 1 year of having the 580.. Nothing appeared to be broke on either one..they just quite firing everytime they should have.... now I carry three with me...just in case!
Ann Robinson:)
My Gear: bunch of stuff;....some I love ... some I hate ... some I can't live without..loving my 5d3...
harcosparky
Sep 20, 2010 18:58 |  #11
How many Canon cords did you break before you switched brands?
windpig
Chopped liver
Sep 20, 2010 20:52 |  #12
harcosparky wrote in post #10945482 (external link)
There are no other brands to switch from. I gave up and went with the ST-E2. Realize that it's not just the contacts going south, but I had a brand new chord fall apart in my hand the first time I slid a flash into it.
harcosparky
Sep 21, 2010 19:53 |  #13
windpig wrote in post #10946095 (external link)
That's odd, I've had mine for a few years and no issues, of course I do not stretch the cord to its fullest, I use it when I have the camera and flash on the strobe-o-frame or whatever the name is.
I did break one in the past, but do not confuse that with having one break, I did something stupid and caused the damage myself. Even though it was damaged it was still useable up until the day it was stolen.
Of course now that I have the 7D I can go cordless and fire off the 550 and 580 remotely and not need to cord.
Vermin87
Sep 21, 2010 20:05 |  #14
I have an OC2 that I've stretched to the limit, soldered, and dropped on the ground and it still works great.
Gear
Website (external link)
4,464 views & 0 likes for this thread, 8 members have posted to it.
1427 guests, 126 members online
