zeldaboy101 wrote in post #10195385
There is definitely a point where the light pollution will overcome the faint stuff in the image...
I disagree with this statement, but perhaps it's the choice of words again. The light pollution never overcomes anything as it always remains the darkest part of the image. This was not true with film astrophotography due to reciprocity failure - the sky glow intensity would actually catch up to the subject eventually, a concept known as the "sky fog limit". But that concept doesn't apply to digital photography since digital sensors aren't subject to reciprocity failure. What happens is that the dynamic range available for the subject decreases when the range taken up by the sky glow increases. This is sometimes refereed to as the digital equivalent of "sky fog limit", but it's really a totally different phenomenon. The stacked image naddieuk posted is nowhere near a reasonable limit for sky glow when working under light polluted skies. I suspect he still had 80% of his camera's dynamic range remaining. With longer exposures, the brightest objects will eventually saturate the detector resulting in loss of image data, but the faintest objects will never be lost or merge into the sky glow until the entire image is solid white.
I'd recommend shooting images at something like 5, 10, 15, 20 sec and so on and do a stack of like 5 of each exposure length, to see which images stack up to give you the best combination of some light pollution without overwhelming the stars. Getting to around 30 seconds is ideal, but sometimes the skies are so bad you can't do that.
Longer is always better, up to the point were your tracking or lack of tracking causes unacceptable star trailing. You are better off reducing the ISO and shooting for the longest exposure time you can manage when light pollution is an issue. You will acquire four times as much signal at 20 seconds and ISO 200 as you acquire at 5 seconds and ISO 800, and the sky glow intensity will be the same. After stacking several exposures, the SNR will be significantly lower with the longer exposures, and post-processing to kill the sky glow and enhance the subject will be easier.
Don
