Is it possible to pack the Canon 7D with the Canon EF 70-200mm f/4.0 L USM lens attached in the Lowepro 202AW. I understand this combination will not work with the Canon EF 70-200mm f/2.8 L IS II USM lens attached, but the Canon EF 70-200mm f/4.0 L USM lens is smaller and I was hoping it would fit.
In the end all you have is some thin, stretched to the limit material between your expensive gear and the outside world...
