I have a Canon 7D, and have been having problems with holding High-speed Sync when using the Speedlight Transmitter ST-E2 with Canon 550 EX flashes. When I set High-Speed Sync, the flash will sync for a few shutter actuations, but then the ST-E2 will revert to normal sync speed. I have tried setting the ST-E2 to both the “On” mode and “Hold” mode, but still get the same results. I have also tried setting the flash to High-speed Sync, but it will also default to normal sync. The 7D flash sync speed is selected to “Auto” in AV mode, and I am shooting in AV mode.
I use the same flash set-up with my Canon 5D MKII, and I do not have the problem. I have also used this set-up with the 40D, 50D, 5D,1D MKII, and 5D MKII without issue.
If I use the Off-camera Shoe Cord 2 I don't have any problem with High-Speed Sync.
I called Canon tech support about this issue, and they told me that everything should work fine with my set-up. They suggested that I put a new battery in the ST-E2, and if I still had the same problem to send the transmitter in for repair. Since it works just fine on my 5D II, I thought maybe someone here could offer a solution.
Thanks, Mary
