Racer997 wrote in post #10195863
1) Many of us casually shoot pix for fun. If we get something we really like, we print it 4x6, 5x7 or maybe even 8x10. Okay, so if my camera is has a max resolution of 8.5 mp, will I see a difference at 8x10 versus a camera that has, say, 15 or 18 or 22 mp? I know I'd see a difference at poster size or bigger, but can the difference be seen at smaller sizes? My opinion is that more resolution makes a better quality image no matter what the size of the print, but the details may not be fully seen. Will a 22mp image look nicer at 8x10 than a 8.5 mp image?
Resolution is the resolution of the lens/sensor combination in line pairs / mm. More pixels only contributes a little more resolution – a 20MP camera does not resolve 2x more than a 10MP camera.
The bigger difference is sensor size. If a 35mm sensor is paired with some lens at some f-stop resolves 50 lp/mm, it will show up as ~7 lp/mm on an 8x10 (I believe the goal is usually 6+ lp/mm for resolution-critical work). To do the same lens on an APS-C sensor requires 1.6x more resolution, or 80 lp/mm. In other words, the APS-C camera needs a much better lens or a much higher resolution sensor to yield the same resolution print.
2) Say my camera has a maximum resolution of 18.1 mp, but I choose to shoot at a lower mp setting. Am I losing image quality because of my first question AND because the image mp reduction causes the camera to lose valuable image data? In other words, does making the image mp smaller via the camera setting strip valuable data and metadata from the image, thus making it less "good" to work with, or, do I not suffer any real losses other than making my image smaller?
You lose some pixels, which loses some detail. So yes, you lose some resolution. What you need to ask yourself is if that lost detail is important to you. If you only print 4x6's, it probably never would have showed up anyway.
That said, resolution is not always the most important thing. In a landscape, maybe you want to make a huge print and be able to walk up to it and see every little leaf or pebble. In that case, you need a high-resolution print. In a portrait, you only need enough resolution to resolve the hair, so it's not as important.
Also, a lot of people don't care much about resolution, they just want an image that looks "sharp," as in well-defined edges.
