Thread started 17 May 2010 (Monday) 12:16
Shutter Speed - the "math" 1/(FL x 1.6)
Cody21
May 17, 2010 12:16 |  #1
Can someone please explain this to me ? I read that the proper SS that I should be using (M mode) should be AT LEAST 1/(FL x 1.6) -- since I have a crop camera.
Examples, I'm shooting a FL of 100mm ...
So for the best chance of a Sharp picture, my SS should be 1/(100X1.6) = 1/160 -- Is this correct? or do I have to take the "mm" into consideration ? And this is a MINIMUM SS, right?
another example - FL of 50mm - I would shoot at a minimum of 1/80 SS ... right?
Thanks in advance.
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
Veemac
May 17, 2010 13:42 |  #2
In theory, you've got it right on all counts. In reality, it will vary from person to person. Some with good technique and very steady hands may be able to get away with a slower shutter speed; some are less steady and may need a considerably higher one. Also (if we're talking about stationary subjects), using IS may allow you to shoot considerably slower without camera shake showing up.
Mac
-Stuff I Use-
E-K
May 17, 2010 13:45 |  #3
In addition to what Veemac said, you need to consider enlargement size. The bigger the enlargement the faster the shutter speed.
e-k
SkipD
Joined Dec 2002
May 17, 2010 14:55 |  #4
Cody21 wrote in post #10196243 (external link)
That is the rule-of-thumb which has been used for 35mm film cameras for decades, modified for the smaller APS-C format.
The one thing you need to realize is that this applies to ALL exposure modes, not just "M" (Manual) mode.
As said in the posts above, the rule-of-thumb will apply to various individuals (and different degrees of enlargement to present images) differently depending on how steadily they are able to hold a camera.
Skip Douglas
gjl711
May 17, 2010 15:01 |  #5
Another thing to keep in mind is that this applies only when the camera is being hand held. If it's on a tri-pod, rested on something, or you very stable like elbows on a wall, then this does not apply. A fast shutter speed does nothing magical to sharpen up pics. It just reduces the effect of camera motion.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Cody21
May 17, 2010 15:04 |  #6
Thanks guys -- makes sense.
mikekelley
"Meow! Bark! Honk! Hiss! Grrr! Tweet!"
May 17, 2010 15:27 |  #7
What's the difference between, say, a 40d, and a 5dmark 2 when it comes to this?
Since pixel density is nearly the same on both cameras, wouldn't you need to use focal length x 1.6 on the 5d2 as well to get pixel level sharpness?
Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography (external link)
How To Photograph Real Estate and Architecture (external link)
My Fine Art Galleries (external link)
My articles at Fstoppers.com (external link)
krb
May 17, 2010 15:32 |  #8
mikekelley wrote in post #10197422 (external link)
This question was recently beaten to death (as you already know): https://photography-on-the.net/forum/showthre​ad.php?t=860274 and E-K already answered it in this thread.
-- Ken
Gear list
neilwood32
May 17, 2010 15:55 |  #9
The rule of thumb is correct 1/(focal length x crop factor) but as suggested, it differs from person to person.
If I use good technique, I can quite often manage double the rule (up until it gets to about 1/2 sec). Shooting without care, I follow the rule pretty well. I find the breath holding gives the biggest effect (think snipers)
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
number ­ six
fully entitled to be jealous
May 17, 2010 16:28 |  #10
The quick synopsis (because I'm not gonna beat that dead horse any longer) is that a 40D's image needs to be magnified 1.6X as much as a 5D's to get the same size print or screen. Any shake will be magnified 1.6X in the process.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
aebrown
Maybe the next victim
May 17, 2010 16:33 |  #11
With the new 70-200 the IS works wonders...
-Aaron Brown :D
1D Mark III, 5D Mark II, 35L, 85L, 70-200 f/2.8L, 580 EX II
Where to goandWhat to do (external link) in the Pacific Northwest
My Flickr (external link)
mikekelley
May 17, 2010 17:55 |  #12
number six wrote in post #10197764 (external link)
-js
So then it doesn't really matter, and we should strive for as high a shutter speed as possible on all cameras, making the 1.6x shutter speed rule a load of you know what?
chauncey
May 17, 2010 18:31 as a reply to  @ mikekelley's post |  #13
I would suggest that is correct unless, your going so fast that you must increase ISO to unacceptable levels to compensate.
number ­ six
May 17, 2010 18:46 |  #14
mikekelley wrote in post #10198307 (external link)
Well, this "rule" is for minimum handheld shutter speeds. Personally, I don't think it's fast enough as a minimum and I try for 2X if I can. Not because I'm particularly shaky, but because we tend to print much larger than we used to in the 35mm film days, where that "rule" originated.
I have a 20 X 30 inch print over my desk, taken handheld with my 6.3 MP 300D. I would never have tried to print a 35mm film shot that large - in fact I think the largest print I ever did with film was 11 X 14.
I wouldn't say "as high a shutter speed as possible", though - there are tradeoffs. How about "high enough", which for me is usually safely 3X. No point in sacrificing noise performance or depth of field to arbitrarily get the shutter speed high.
-js
"Be seeing you."
krb
May 17, 2010 19:08 |  #15
Perhaps you've misread some posts? 1.6x is a guideline for the minimum shutter speed when shooting hand held.
-- Ken
Gear list
3,678 views & 0 likes for this thread, 13 members have posted to it.
2529 guests, 169 members online
