Thread started 17 May 2010 (Monday) 14:46
Baseball/Softball Batted Ball on the Bat?
nicshow
May 17, 2010 14:46 |  #1
I know some of you will say that talent is key to getting the ball on the bat or just coming off the bat (and that's probably true). I'm also hoping that burst rate of a body has something to do with it! :)
I'm shooting with a 30D and am continually disappointed to most often miss having the ball in the frame. Aside from a 1D Mark, would I benefit from upgrading to a 40 or 50D to get improved burst rate?
Thanks!
Nic
http://www.flickr.com/​photos/nicshow/ (external link)
http://www.nicshowalte​r.com (external link)
MT ­ Stringer
May 17, 2010 14:51 |  #2
Most of my bat on ball shots are the first image of the swing. Even 10 fps won't catch on the scond frame. I try to time it one the first one.
MaxPreps Profile (external link)
My Gear List
NickJushchyshyn
May 17, 2010 15:11 |  #3
Talent is a myth. (http://michaelmistrett​a.com/2009/the-myth-of-talent/ (external link))
Burst rate has very little to do with it (besides if it did, you'd only ever get a ball on bat shot with something like a 1D). Virtually none of my own ball-on-bat shots happened on a second or 3rd frame of a burst (even with a 1D). The ball is only in frame for one shot ... generally the first if I timed it right.
Practice is the solution.
There are a couple indicators that you can practice on watching....
1) Practice seeing the pitcher and batter at once. When setup near 1st or 3rd base, it's possible to have one eye on your finder looking at the framing of the batter, and your other eye seeing the pitcher (looking outside the camera). This way you can watch the pitch release and time your shutter press based on the pitch. In this way, you actually time yourself the same way the batter does (you just don't have to aim to hit the ball with a bat).
2) Watch the batter's shoulders and practice timing your shutter press just when the batter starts to move. The batter is timing his/her swing to anticipate the arrival of the ball ... you've got a split-second to read that move and shoot in time with the ball's arrival.
www.techvantics.com (external link)
Mike ­ R
May 17, 2010 19:24 |  #4
I agree with the others. Burst is not needed to get the ball on or near bat. I find it helpful to pay attention to the suttle movements a batter makes just prior to the swing. If you hear the hit, you missed it.
Mike R
www.mikerubinphoto.com (external link)
nicshow
May 17, 2010 19:47 as a reply to  @ Mike R's post |  #5
This is very interesting and I thank those of you who have shared. So, do some of you actually just shoot in one-shot mode and not even bother bursting?
Nic
MT ­ Stringer
May 17, 2010 19:58 |  #6
8 fps on the 7D and 10 fps on the MK3
Check this out.
https://photography-on-the.net/forum/showthre​ad.php?t=874726
My Gear List
snyderman
May 17, 2010 20:10 |  #7
As you may have discovered, the 30D doesn't record what is actually happening at the time of shutter actuation. If you're trying to time your shot when the ball enters the hitting area, too late. Heck, even the 50D has a decent lag. Not sure if the 30D is any slower, but to get the shot you're looking for you have to start shooting when the batter starts his/her swing.
dave
Canon 5D2 > 35L-85L-135L
lazer-jock
Don't mess
May 17, 2010 21:27 |  #8
IMAGE: http://lh5.ggpht.com/_PhY4-rZzeEI/S5Jq2wcnutI/AAAAAAAABUs/GRR9TpJ1-98/s800/IMG_7016.JPG
Shot with a 450D & 70-300 IS
(170mm, 1/512 s, f/6.4, ISO100)
It was my first outing at a baseball game, so I was learning (playing with one parameter while letting the other auto-adjust to see what I needed to do). If I had been a hummingbird's heartbeat faster on the shutter, I would have caught the ball right on the bat. Now, I still like to get the ball in the frame, but I focus more on trying to capture expressions since they make for more compelling pictures (IMO).
I'm off lining my cage with newspaper.
My Gear List
jacuff
May 18, 2010 12:13 |  #9
Just slow your shutter-speed down to 1/1600. You'll get it every time.
IMAGE: http://www.justinacuff.net/potn/872950-05.jpg
Ok, not really, but dragging it just a little bit helps. :)
It's a lot a bit skill and a lot a bit luck. My experience is it isn't at all about the burst rate. I burst for contact in the first frame and expression in 3rd or 4th, though a burst of 2 is most common.
Gear, Feedback (eBay (external link)), Web (external link), Blog (external link), FB (external link), Twitter (external link)
nicshow
May 18, 2010 20:59 as a reply to  @ jacuff's post |  #10
This is very interesting and educational - thank you to all who have contributed!
MJPhotos24
Joined Nov 2005
May 19, 2010 13:11 |  #11
nicshow wrote in post #10197180 (external link)
Not really either, more of timing and knowing your camera while having the right settings dialed in to achieve a good BOB shot - yes, there's good and bad ones. Spray in a little luck as well.
MT Stringer wrote in post #10197202 (external link)
With all my bodies except the Mark III this is true, for some reason with the III I get BOB and release point photos with the second frame, just how I learned the timing with the thing and not sure how it happened! IIn it's always the first shot, III it's always the second. Strange...
NickJushchyshyn wrote in post #10197330 (external link)
Talent is not a myth, I know some that have studied like mad, know a LOT about the gear they have, have all the best gear, and still don't put together consistent professional results. They might work their a$$ off learning this and that but still just don't "have it". You need a certain amount of talent, hell some would say being able to study and learn is a talent because others don't have the patience for it!
Watching the pitcher and hitter makes no sense at all to me, zero. You're not timing it like a hitter does in any sense. It's all about timing the hitters back shoulder and hip action, nothing really at all to do with the pitcher except he happens to be there somewhere throwing the ball to hit.
jacuff wrote in post #10203197 (external link)
I rarely go for BOB shots, they simply do NOT sell editorially or stock wise, but if anything you want your shutter as high as humanly possible. I will NOT go for a BOB shot unless my shutter is at 1/5000 or above. You want the ball/bat frozen, not blurry. Often times even 1/5000 or 6400 isn't enough for that. I've got some at slower shutters and just not good BOB shots IMO.
Freelance Photographer & Co-founder of Four Seam Images
Mike Janes Photography (external link) - Four Seam Images LLC (external link)
FSI is a baseball oriented photo agency and official licensee of MiLB/MLB.
@FourSeamImages (instagram/twitter)
@MikeJanesPhotography (instagram)
@MikeJanesPhotog (twitter)
nicshow
May 20, 2010 06:06 |  #12
All of you are so helpful - would you mind answering 2 more questions?
At the kind of focal lengths used for shooting from the typical sideline positions, what is your "typical" aperture? at 200 to 300 mm, I've always felt safe with f4 although at times have gone a little bigger.
And, are all of you using the * button to focus or does anyone rely on autofocus (I saw someone mention autofocus somewhere I think)
Thank you!
10megapixel
"I'm a little slow"
Location: Â…Â…Surrounded by Corn and Rednecks in Indiana
May 20, 2010 06:14 |  #13
nicshow wrote in post #10214656 (external link)
Thank you!
I always shoot wide open ( 2.8 ) and use the * button to auto focus.
Gear List & Feedback
DDCSD
GIVIN' GOOD KARMA
May 20, 2010 17:35 |  #14
Even 30fps is worthless for getting a BOB shot.
http://www.sportsshoot​er.com …_feature/30fps/​index.html (external link)
If you really want to get fairly consistent BOB shots, you're going to have to work on your timing. While I think that most BOB shots are just about worthless, it does work as a great exercise in timing your shots.
Kind of like how target shooting helps for hunting. It is good to get to where timing is second-nature and you can concentrate on the other things that are vital to a great photograph.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
MJPhotos24
Joined Nov 2005
May 20, 2010 20:34 |  #15
Thank you!
What you shoot at depends on what you want, what gear you have, what focal points you're using, how close you are, etc. If you have a 400 you're going to be a lot closer than a 200 so could go to f/4 or 5.6 and get the same or better background blur than the 200 at 2.8 if they're standing right next to you - it's all dependent on several factors and no perfect answer. In any given game I shoot from 2.8 to even 22 at times (rare, but happens)...usually top out around 11, which is one more than 10.
Always use the * button to focus to, helps a lot!
4,246 views & 0 likes for this thread, 11 members have posted to it.
1036 guests, 107 members online
