Thread started 17 May 2010 (Monday) 14:55
CameraSlingers or Black Rapid ???
JChin
Joined Jul 2004
May 17, 2010 14:55 |  #1
Do you guys use any of these camera straps for your wedding shoots?
Camera Slingers - http://www.camerasling​ers.net/ (external link)
or
Black Rapid RS-7 http://www.blackrapid.​com/product/camera-strap/rs-7/ (external link)
or
Black Rapid Double http://www.blackrapid.​com …amera-strap/double-strap/ (external link)
I want something that can help off-load the weight of the camera, without the use of an extra assistant :D
Is there a system that can be used as a single and a double as needed?
Thanks.
Johnny J. Chin ~ J. Chin Photography (external link)
Facebook (external link)Flickr (external link)SmugMug (external link)Zenfolio (external link)
I shoot with Canon gear.
40DRN
May 17, 2010 15:07 |  #2
If I'm right?? I think you can buy two black rapid straps and buy a coupler which makes the two straps a double strap. Then you can take out the coupler if you only intend to use one strap. Hope I answered your question right??? :)
JChin
Joined Jul 2004
May 17, 2010 15:39 |  #3
Yes you have, but I am also looking for comments about these systems. I am curious how well they work mounted to the tripod mount.
kingdaddy
May 17, 2010 18:43 |  #4
JChin wrote in post #10197491 (external link)
If you have a grip you could mopunt it like this, works great for me.
6D | 7D | XSI | EF-S 10-22 | EF 50 1.4 | EF 24-105L | 100-400L │ EF-100mm Macro| MT-24EX │580 EXII | Black Rapid RS-5 | lots of Think Tank.
JChin
Joined Jul 2004
May 17, 2010 19:46 |  #5
How did you connect to the bottom? What is that ring?
TXLEBER
May 17, 2010 19:48 |  #6
I have used both the Black Rapid Coupler system and the Double strap for weddings. Using the Tripod mount is the only way I'd carry my 70-200. I would recommend using the Double Strap system. It can be separated to be used as a single sling system as well.
As far as the Cameraslinger system, I thought about it, but it looked too much like a bra!...lol.
Lionel
May 17, 2010 19:58 |  #7
kingdaddy wrote in post #10198571 (external link)
Why don't you use the D ring from the tripod mount.....thats what I use and never had a problem.
JWright
Joined Dec 2004
May 17, 2010 19:59 as a reply to  @ kingdaddy's post |  #8
My preference between the two straps listed by the OP would be the Black Rapid Double strap, for a couple of reasons.
One, the BR has a chest strap and the Camera Slinger doesn't. I'd want the extra security... Two, the clip on the Black Rapid is more secure. It actually locks closed, while, as near as I can tell, the one on the Slinger is spring-loaded and could catch on something and open accidentally.
I actually took two of the original Black Rapid straps and converted them into a double using THIS (external link) modification. I took it a step further and added a Black Rapid BRAD (external link) as a chest strap. While my straps can be broken down into a pair of singles, I went ahead and purchased an RS-7 for those times when I shoot with only one camera.
John
JChin
Joined Jul 2004
May 17, 2010 20:13 |  #9
Lionel wrote in post #10199087 (external link)
Because my Stroboframe QR does not have a D-ring :(
lannes
May 17, 2010 20:21 |  #10
JChin wrote in post #10199166 (external link)
Even though I use Black Rapids, the Luma Loop has a more flexible mounting solution for the tripod mount problem, their lanyard can be attached to any strap mounting point.
But they don't produce a double strap.
lannes
May 17, 2010 20:28 as a reply to  @ lannes's post |  #11
I would also look at Cotton Carriers and Spider holsters, the main issue I see with the double straps is that the cameras will swing around a lot and if you need to bend over or crouch down then they could swing down and hit the ground or other objects. I think for wedding photography where you are trying to get creative angles, trying to stabilise one or both cameras all the time is a bit messy.
If you only use one camera then the sling style strap is a good option.
JWright
Joined Dec 2004
May 17, 2010 20:42 |  #12
lannes wrote in post #10199207 (external link)
For those that use Arca-Swiss style brackets and plates on their cameras and lenses, the solution is simple. I attached the Black Rapid hardware to a compatible clamp available from Kirk and I use that to connect the strap to the camera.
IMAGE: http://johnwright.smugmug.com/Photography/My-Gear-1/IMG293-9342-G5/840578790_y8pXg-L.jpg
John
kingdaddy
May 17, 2010 21:52 |  #13
Because you can quickly attach it to a tripod head without removing the strap. Its just a small key ring and is strong enough to hold any lens combo I use like the 100-400L.
johnlo
May 18, 2010 07:54 |  #14
Johnny : ask Chris Chen. he has the Double from BR.
johnlo photography :
website: www.john-lo.com (external link)
personal blog: http://www.jklimagery.​com (external link)
My Gear List
JChin
Joined Jul 2004
May 18, 2010 09:56 |  #15
Thanks John. I'll FB message Chris.
4,497 views & 0 likes for this thread, 8 members have posted to it.
1472 guests, 132 members online
