Thread started 17 May 2010 (Monday) 15:36
Should I use a gel filter to shoot on cloudy days?
picard
May 17, 2010 15:36 |  #1
I already set the 7D on cloudy days setting but it still doesn't look bright.
How do I get the clouds to look blue ?
Canon 1DM4,7D, Rebel XT
580 EX II, 430 EX II
Canon 70-200mm IS II L , Canon 85mm F1.2 L II, Canon macro 100mm F/2.8, 18-55mm kit
Sigma 18-200mm F/3.5-5.6, Sigma 10-22mm, Sigma 50mm F/1.4
Sigma 24-70mm F/2.8 EX DG HSM
crn3371
May 17, 2010 15:40 |  #2
I always thought clouds were white, sky was blue. If it's a sunny day with blue skies and white fluffy clouds then you might want to look in to a circular polarizer. Under the right conditions it will accentuate the contrast between the clouds and the sky, make the sky bluer, and the clouds whiter.
neilwood32
May 17, 2010 15:42 |  #3
Clouds shouldnt look blue!
You can alter the colour of some things but unless you are going for a completely unreal look, I wouldn't suggest the use of a filter.
As CRN suggests, a polariser will possibly increase contrast thereby improving the shot.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
picard
May 17, 2010 15:42 as a reply to  @ neilwood32's post |  #4
oops. I meant the sky doesn't look blue. hehehe
rral22
May 17, 2010 16:25 |  #5
I approach all color control with camera settings and software in post. I use no filters for influencing color except for a polarizing filter which does things I can't manage to do any other way.
tzalman
Fatal attraction.
May 18, 2010 08:01 |  #6
Shoot RAW, set or tweak color temperature in post.
Elie / אלי
SkipD
Joined Dec 2002
May 18, 2010 08:09 |  #7
picard wrote in post #10197475 (external link)
You can use the tools in your camera to set up a Custom White Balance or you can tweak colors in post-processing (more easily done if you shoot in RAW mode). You do NOT need to use filters on the lens.
If you are using flash to supplement sunlight (or artificial continuous lighting), you might want to gel the flash to match the color of the continuous lighting.
Skip Douglas
2,747 views & 0 likes for this thread, 6 members have posted to it.
2755 guests, 174 members online
