Thread started 17 May 2010 (Monday) 22:19
storing your lenses
Maiko
May 17, 2010 22:19 |  #1
I know this question may seem silly but I would like to know the proper orientation (lens facing up/down/sideways) to store them when not in use. thanks!
GJim
May 17, 2010 22:23 |  #2
As long as both caps are in place, I don't see any great difference in storage orientation. I store all mine lens facing down, in photo-vest - but that's more for quick change-out than any other reason. I know that when I reach for a lens which direction it is facing.
G'Jim c):{- ... 2x 50D (Both Gripped), 2x 7D (Both Gripped), 2x 5D Mk II (One gripped), 1x 60D, assorted glass (10-800mm), sundry accoutrements.
The beginner clicks the shutter and says "Let's see what I got." ... The experienced photographer thinks "How can I capture what I see?"
My Photography: http://www.gjimphotogr​aphy.com (external link)
jcarp618
May 17, 2010 22:45 |  #3
like the guy above me stated, it really makes no difference. my backpack opens from the back and i like the front of the lens to be facing my back...no real reason, just did it from the beginning.
Headshotzx
May 17, 2010 22:49 |  #4
I have a digital dry cabinet with curvy foam insert for my stuff, so they lay with the glass horizontal, lens caps on. But it makes no difference how you put them.
Zexun | Flickr (external link) | YouTube (external link) |
shannyD
"...in too much trouble"
May 17, 2010 22:51 |  #5
mine are all in a pelican case..laying down.. but the case is stored standing up.. putting the lenses, lens to the ground. but all caps are on.
Jon
Joined Jun 2004
May 18, 2010 11:00 |  #6
However they fit in whatever they're sitting in.
Jon
Cocker Spaniels
hairy_moth
May 18, 2010 11:27 |  #7
Both lens caps on.
My only other thought would be to keep them from extreme conditions (e.g., damp basement, attic). Besides that.. wherever, however.
7D | 300D | G1X | Tokina 11-16mm f/2.8 | EF-S 17-55mm f/2.8 | EF-S 60mm f/2.8 Macro | EF 85mm f/1.8 | 70-200 f/2.8L MkII -- flickr (external link)
JJD.Photography
May 18, 2010 12:06 as a reply to  @ hairy_moth's post |  #8
My telephotos are stored faced down. The smaller lens on their side. All with both caps in place & all in a Pelican 1624 when not in use :cool:
His And Her Photographs (external link)
ben_r_
-POTN's Three legged Support-
May 18, 2010 13:05 |  #9
This has been asked before. It really doesnt matter. I happen to store all of mine front element down, but thats just bc I prefer to grab them by the rear of the lens and bc my pelican case is deep enough to stand them up so I wouldnt lay them down.
photopat
May 18, 2010 13:41 |  #10
you need to store them horizontally, in the dark and rotate them once a week to avoid any dust deposit drying out on the bottom.
The temperature and humidity should be controlled.
Also after using them, you need to remove all air from in it (with a vacuum pump), or replace the air with nitrogen.
The older they are, the more care you should take of them. But the white ones can not be kept as long as the others.
Also, be aware that the ones made in 2008 are not that good. You should prefer a 2009 or 2007 model if you can.
Use them with moderation, and don't drive after using one.
Patrick, an Lcoholic
toys list
trant6
May 18, 2010 16:25 |  #11
photopat wrote in post #10203783 (external link)
Any particular reason why they should be stored horizontally? I tend to rest them on the front element as well (both caps on of course).
Octowl
May 18, 2010 16:36 |  #12
as long as you dont store them in the garage...summer heat will break things eventually.
My name is Daniel and I'm a Graphic Designer, but my passion is Photography
Canon EOS 60D | 10-22mm f/3.5-4.5 USM | 55-250mm f/4-5.6 IS | 50mm f/1.8 | 85mm f/1.8 USM | 580EX II | D-Lite-4 IT | Glidecam HD2000
Full Gear List | flickr (external link) | Google+ (external link)
photopat
May 18, 2010 16:44 |  #13
trant6 wrote in post #10204698 (external link)
I should add that I don't like too much the white ones, I prefer the red ones.
bw!:lol:
toys list
Jon
Joined Jun 2004
May 18, 2010 17:25 as a reply to  @ photopat's post |  #14
I think he doesn't want the corks to dry out and let the contents oxidize. It also lets the sediment collect so decanting is easier. I'm surprised he didn't mention the preferred temperature of 45-55 F (10-15 C). All that's wonderful directions for caring for your wine, especially the vintage port that your grandfather laid down at your birth for toasting your first grandson, but a trifle overboard for the lenses in your camera bag.
Jon
Cocker Spaniels
trant6
May 18, 2010 18:20 |  #15
photopat wrote in post #10204813 (external link)
LOL, guess I should've read the entire post before replying :oops:
2,819 views & 0 likes for this thread, 12 members have posted to it.
storing your lenses
2743 guests, 154 members online
