Looking for feedback from 7D users who shoot fast action:
Do you find that the camera focuses better in overcast conditions and/or when the contrast in your scenes is lower?
TAZorich Member 237 posts Joined Feb 2008 Location: Middletown, DE More info | May 18, 2010 10:07 | #1 Looking for feedback from 7D users who shoot fast action: 5DM2 | 7D | 600/4.0 IS | 50/1.4 | 24-70/2.8 | 70-200/2.8 | 580EXII (x2) | Quantum Qflash | Sekonic L-358 | Photogenic monolights | Tamrac bags | Bogen/Manfrotto supports
Invertalon Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | May 18, 2010 10:19 | #2 |
Well, you'd think that might be the case. 5DM2 | 7D | 600/4.0 IS | 50/1.4 | 24-70/2.8 | 70-200/2.8 | 580EXII (x2) | Quantum Qflash | Sekonic L-358 | Photogenic monolights | Tamrac bags | Bogen/Manfrotto supports
aboss3 Goldmember 2,616 posts Joined Jan 2010 Location: LOS ANGELES More info | May 18, 2010 11:24 | #4 Permanent banHigh contrast leads to faster focusing. If you do this test at home, and try to focus on something that has one solid color, i.e. - white door, your AF will keep on hunting and hunting. Then focus on just the handle, and recompose. Gear | My gear is changing faster than I can update the signature
May 18, 2010 11:36 | #5 aboss3 wrote in post #10202893 High contrast leads to faster focusing. If you do this test at home, and try to focus on something that has one solid color, i.e. - white door, your AF will keep on hunting and hunting. Then focus on just the handle, and recompose. Your statement is not backed up by your proposed test. 5DM2 | 7D | 600/4.0 IS | 50/1.4 | 24-70/2.8 | 70-200/2.8 | 580EXII (x2) | Quantum Qflash | Sekonic L-358 | Photogenic monolights | Tamrac bags | Bogen/Manfrotto supports
Sloany Member 65 posts Joined Nov 2006 More info | I have the same results with my 40 and 50d with either a
oldvultureface Goldmember More info | I think it's similar to shooting a mirror. The mirror won't be in focus, but what is reflected in the mirror will be. Same with objects of varying distance reflecting off your subject in bright, contrasty light. Try to focus on highly reflective surface and you're more likely to get in focus what is reflected from that surface.
May 19, 2010 10:44 | #8 Let's try this as a comparison.
May 19, 2010 10:50 | #9 Now let's look at six photos that were taken when the weather improved, using identical camera settings (but manual exposure adjusted for brighter conditions):
What focus points were used? It seems like nothing in the second set of photos is in focus. The second set looks like you were closer,is that so?
MrGreen Goldmember 1,252 posts Joined Jan 2008 Location: Vancouver, BC More info | May 19, 2010 11:15 | #11 TAZorich wrote in post #10209553 Let's try this as a comparison. First, we'll look at the "good" set - that is, where the photos - while not "tack sharp" - are at least good enough to sell. These six photos were shot in cloudy/overcast conditions, using a 7D in manual exposure mode, AI Servo focus mode, with a Canon 600/4.0 IS lens. Here are two sets of three consecutively-shot photos, taken on two consecutive laps. The rider isn't in focus at all. Neither is the rider in the sunny conditions either. Your photos aren't really making your case because BOTH sets are OOF, and honestly I wouldn't buy any of them. My site: www.millionflame.com
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | May 19, 2010 11:34 | #12 I've got a straight sequence of 23 frames in 3-4 seconds from my 7D and 100-400 of a BIF in bright sunshine and I'm happy with the focus on all of them. Slideshow of unedited files here....
Invertalon Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | May 19, 2010 11:42 | #13 |
yourdoinitwrong Goldmember 2,394 posts Joined Apr 2009 Location: Indiana More info | I might be wrong (and probably am) but isn't the focusing more dependent on the contrast of the subject than what the weather is doing? Yes, I know that bright sunlight should create more contrast but you would have to test identical subjects under the two different lighting conditions with identical settings to really see what is going on. To my thinking, if you are using a small focus area pointed at a solid color area of the subject then the AF is going to have some difficulty regardless of whether it's cloudy or sunny. I usually use Point Expansion and have not seen any difference in focusing between cloudy or sunny. 5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
May 19, 2010 11:50 | #15 mrgooch: 5DM2 | 7D | 600/4.0 IS | 50/1.4 | 24-70/2.8 | 70-200/2.8 | 580EXII (x2) | Quantum Qflash | Sekonic L-358 | Photogenic monolights | Tamrac bags | Bogen/Manfrotto supports
| Latest registered member is bzguy 1573 guests, 196 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
