Thread started 18 May 2010 (Tuesday) 15:01
Can my 7D take this CF card?
7D_Sniper
May 18, 2010 15:01 |  #1
Came across this card for a pretty good price and would like anyone's input on this card or if it can even be used in my Canon 7D? Thanks in advance
Seagate ST1 5GB CompactFlash Type II 1" Hard Drive ST650211CF-R
Features/Specification​s:
* Seagate ST1 5 GB CompactFlash 1-inch Hard Drive
* General Features:
* 5 GB capacity
* Sectors: 9,767,520 (512 bytes/sector)
* Type II CF+ interface
* 1-inch form factor
* 3600 RPM speed
* 2 MB cache buffer
* 16.0 ms average seek time (Read)
* 8.3 ms average latency
* Designed for embedded use only
* Power Specifications:
* Input: +3.3V DC
* Regulatory Approvals:
* FCC
* CE
* CSA
* cULus
* C-Tick
* BSMI
* MIC
Additional Information:
* Model: ST650211CF
* P/N: 9AF212-001
* Be sure the device used can take up to 5 GB capacity.
* In order to use this CompactFlash in a camera to the full extent, the camera needs to support FAT32 File System.
* Product Requirements:
* CF Type II slot
Run it's the big bad amateur
GEAR & FEEDBACK
Help Support POTN
My Blog (external link)
http://www.hooddesigns​.com (external link)
rvdw98
May 18, 2010 15:19 |  #2
You didn't mention what you call a "pretty good price", but an 8 GB flash based CF card sells for around 20 bucks, is not susceptible to shock damage, and has more capacity than the 5 GB micro drive you listed. Not to mention that it's probably faster and easier on your camera's battery.
I don't know anyone who still buys micro drives for their DSLR.
Roy
int2str
May 18, 2010 15:20 |  #3
7D_Sniper wrote in post #10204237 (external link)
I would not use that for any of my photos. You can decide for yourself how much your photos are worth to you.
That drive will fit and should work in the 7D. But, it will be slow compared to modern CF cards and also be questionably reliable, given it's tiny moving parts. It looks like you can get these for under $10 bucks, but is that really worth loosing your photos over?
You bought a nice camera, now by a proper card for it... :p
Here's one for around ~$70:
http://www.adorama.com …uctPage/IDSCFEP​8G60M.html (external link)
There are others that can be had cheaper as well.
7D_Sniper
May 18, 2010 15:29 as a reply to  @ int2str's post |  #4
Thanks for the replies, I do have proper cards for my camera but for $6 bucks i figured if it was compatible why not have a couple of extra cards lying around.
GEAR & FEEDBACK
Help Support POTN
Jon
Joined Jun 2004
May 18, 2010 18:09 |  #5
Thought I'd replied to this. Must have been called away from the computer. Anyhow, I seriously doubt it will. Note the "Designed for embedded use only". That generally means that it's meant for use as a permanently installed drive in something like an MP3 player. If you Google the part number, you'll find a lot of people on photo forums asking why it doesn't work on their cameras. So save your money.
Jon
Cocker Spaniels
7D_Sniper
May 18, 2010 19:09 as a reply to  @ Jon's post |  #6
@ Jon thanks man I was wondering what the embedded part meant. I'll def pass this one up Thanks again
GEAR & FEEDBACK
Help Support POTN
1,093 views & 0 likes for this thread, 4 members have posted to it.
2700 guests, 147 members online
