Most of us use image stabilized lenses and I was wondering...what shutter speed is required to render IS a moot point and is it dependent on the individual lens' focal length?
May 19, 2010 09:50 | #1 Most of us use image stabilized lenses and I was wondering...what shutter speed is required to render IS a moot point and is it dependent on the individual lens' focal length? The things you do for yourself die with you, the things you do for others live forever.
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | May 19, 2010 09:54 | #2 I would think it's more dependent on how steady the shooter is.
May 19, 2010 09:57 | #3 1/Focal length* crop factor is what I use for a handholding rule of thumb and it usually yeilds a decent shot. I can go a lot lower than that with proper technique and no coffee.
nicksan Man I Like to Fart 24,738 posts Likes: 53 Joined Oct 2006 Location: NYC More info | May 19, 2010 10:01 | #4 I also usually do the 1/FL*CF for simplicity's sake. I'll probably bump up the shutter speed a little to give me more margin if there's ample light.
I must have phrased my question poorly. I understand the normal "Rule of Thumb" of 1-1.5 SS/focal length suggestions but there has got to be an upper limit of SS that would render the IS irrelevant. The things you do for yourself die with you, the things you do for others live forever.
Snydremark my very own Lightrules moment More info | I think this still would be based more on the shooter rather than an absolute number. - Eric S.: My Birds/Wildlife
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | May 19, 2010 11:45 | #7 chauncey wrote in post #10209832 As an example, if one used a 200mm lens on a FF body and had sufficient light for 1/1000 SS...would IS even be necessary? Is there a ratio that would render IS unnecessary? That would probably depend on how steady the shooter is. I don't think you'll find a "ratio" that would work in any general sense.
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | I drink way too much coffee. I would probably still benefit from IS at 1/8000s
tonylong ...winded More info | May 19, 2010 11:50 | #9 chauncey wrote in post #10209832 I must have phrased my question poorly. I understand the normal "Rule of Thumb" of 1-1.5 SS/focal length suggestions but there has got to be an upper limit of SS that would render the IS irrelevant. As an example, if one used a 200mm lens on a FF body and had sufficient light for 1/1000 SS...would IS even be necessary? Is there a ratio that would render IS unnecessary? Chauncey, it sounds like you are asking a technical question, as in how fast does the shutter speed need to be to actually cancel the effects of IS, right? Interesting question but I haven't a clue. A zillion Tony
nicksan Man I Like to Fart 24,738 posts Likes: 53 Joined Oct 2006 Location: NYC More info | May 19, 2010 11:53 | #10 chauncey wrote in post #10209832 As an example, if one used a 200mm lens on a FF body and had sufficient light for 1/1000 SS...would IS even be necessary? Is there a ratio that would render IS unnecessary? Generally speaking, no. IS can actually work against you if you are tracking a moving target. At 200mm and 1/1000, when tracking a subject I would have IS turned off.
toxic Goldmember 3,498 posts Likes: 2 Joined Nov 2008 Location: California More info | May 19, 2010 16:13 | #11 With a 70-200/4 IS at 200mm, SLRGear shows improvement all the way to about 1/800 on a 20D, for a shaky person.
as in how fast does the shutter speed need to be to actually cancel the effects of IS, right? Well put Tony...my literary abilities are on par with my photographic abilities. The things you do for yourself die with you, the things you do for others live forever.
| Latest registered member was a spammer, and banned as such! 2755 guests, 174 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
