Thread started 19 May 2010 (Wednesday) 16:29
Canon Pixma 9000 Gamut Range ?
Diver-Down
May 19, 2010 16:29 |  #1
I am currently using a Canon Pixma iP4700 printer. I have been having trouble with color matching and have been through all the settings. I recently had a picture of someone in a blue jacket and when printed the jacket came out purple. Well I just tried printing the picture through CS5 and noticed that, in the preview with [Gamut Warning] selected, most of the jacket is grayed out. So I loaded the printer test chart here:{ http://www.digitaldog.​net/tips/ (external link) } and found that 80-90% of the 2 color bars at the top were grayed out, out of Gamut.
So my question is, how much better can I expect the Gamut Range of the Pixma 9000 to be ?
I have a NIB Pixma 9000 for sale but am considering keeping it for myself if I knew for sure that it would solve my color problems.
Sdiver2489
Joined Sep 2009
May 19, 2010 17:00 |  #2
Diver-Down wrote in post #10211631 (external link)
Post the picture here and I can check if its still out of gamut for you. However, Paper type plays a huge role in printer color gamut. What paper are you using? Matte papers tend to have larger gamuts.
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
Diver-Down
May 19, 2010 17:30 |  #3
Sdiver2489 wrote in post #10211801 (external link)
I've been using mostly Canon Glossy II but have also tried RR Polar Gloss and Ilford Smooth pearl which is semi gloss to matt. I just tried the RR and Ilford profiles on the Digital Dog "Printer Test File" and they are slightly better but still allot out of Gamut.
Here is the picture with the blue jacket that always prints purpleish for me..........
Diver-Down
May 19, 2010 17:43 as a reply to  @ Diver-Down's post |  #4
Here are some screen shots showing the gray "Gamut Warnings" I'm seeing. I realize that these are not fine lines and grayed areas will often print fine but this seems excessive.
FlyingPhotog
Cream of the "Prop"
May 19, 2010 17:45 |  #5
Your monitor is calibrated, yes? If your printing is that mission critical, you can always profile the printer as well...
Jay
Diver-Down
May 19, 2010 17:54 as a reply to  @ FlyingPhotog's post |  #6
Yes, monitor is calibrated.
My printing jobs really aren't very critical and I don't do allot of printing but it really pee's me off when I spent the time editing pictures to look the way I want them to, then the print comes out looking totally different.
Grimes
May 19, 2010 18:29 |  #7
I have a pro9000, and it is great in terms of the color it can reproduce. I get gamut warnings too, but the colors are very, very close. FYI, there is a new driver for the printer that increases the bit depth when printing. Haven't done any back to back comparisons, but the images look great.
Alex
5DMKII | 85 f/1.8 | 17-40L f/4 | 24-105 f/4 IS | 40 f/2.8
Sdiver2489
Joined Sep 2009
May 19, 2010 18:44 as a reply to  @ Grimes's post |  #8
First of all, I get about the same gamut warning as you on the 9000 no matter what paper I use, so it must be a pretty universally hard to print color.
But secondly...maybe I have a different definition of purple...but that jacket is not what I would call blue. Maybe a blue-ish purple...but its pretty darn purple as is. I guess I would call it a blue-tinted lavender...but again...we all have different definitions of purple/blue.
Gear:
Diver-Down
May 19, 2010 19:12 |  #9
Sdiver2489 wrote in post #10212286 (external link)
Well, now I really don't know what to do. Did you try the Digital Dog File ?
I agree, the jacket isn't really a true blue in the picture but my prints have very little blue in them. Below is the picture above that I adjusted to look like my prints, this is pretty close to what I get.............
ChasP505
"brain damaged old guy"
May 19, 2010 20:14 |  #10
Diver-Down wrote in post #10211943 (external link)
I wouldn't have used the DigitalDog test image unless you were working completely in the Colormatch RGB color space. Even Andrew Rodney purports to be using ProPhoto RGB lately. There are many better print test images available tagged in sRGB and Adobe RGB.
http://www.northlight-images.co.uk …le_pages/test_i​mages.html (external link)
And have you tried printing in both Perceptual rendering intent AND Relative intent?
Chas P
ChasP505
May 19, 2010 20:32 |  #11
...So my question is, how much better can I expect the Gamut Range of the Pixma 9000 to be ?
This test comparison rates the Pixma Pro 9000 Mk II as covering 40% of the Adobe RGB gamut. I'd suspect it covers most of the sRGB space, doing better in some color tones, worse in others.
http://www.printerinfo​.com …120/Color-Performance.htm (external link)
Chas P
Sdiver2489
Joined Sep 2009
May 19, 2010 20:41 |  #12
ChasP505 wrote in post #10212700 (external link)
Good point...when I proof his image Relative makes it MUCH more purple than perceptual which actual makes it MORE blue.
Gear:
ChasP505
May 19, 2010 20:59 |  #13
Sdiver2489 wrote in post #10212823 (external link)
Just what I'd expect. Relative tends to clip out of gamut colors.
http://www.cambridgein​colour.com …olor-space-conversion.htm (external link)
The inkset on my HP printer has a special blue ink to extend the printer's blue performance far beyond sRGB. I believe the Epson 1900 has a similar orange ink.
Chas P
Diver-Down
May 19, 2010 21:07 as a reply to  @ Sdiver2489's post |  #14
Thanks for the info guys !! I'll read up on that tomorrow.
I have tried both rendering intents. I should have mentioned that I was using RC above. Overall I have found RC to be a better match but Perceptual does do a much better job with the blues in THIS picture, but then the other colors don't match as well. Other pictures I have tried that have off color blues in them have come out on the purple side as well in both intents.
ChasP505
May 19, 2010 21:21 as a reply to  @ Diver-Down's post |  #15
Wellll.... The answer to the 9000 question is you'll see less objectionable color shifts with intense colors. If you're primarily doing portrait or landscape photos, Relative is fine.
Chas P
4,456 views & 0 likes for this thread, 5 members have posted to it.
1332 guests, 137 members online
