Thread started 20 May 2010 (Thursday) 00:23
EOS 5D classic DIY repair (partial disassembly instructions)
shaftmaster
May 20, 2010 00:23 |  #1
NOTE: I don't recommend that anyone disassemble a camera body unless you are familiar with the proper precautions and techniques to avoid injury to yourself and/or causing damage to your camera. I will not be held responsible for any damage you may cause to your camera or any injury you may sustain if you choose to do what I'm about to describe.
I bought a used EOS 5D classic body about six months ago and was very happy with it. I started having Err99 problems about a month later which I was able to fix by cleaning the lens and battery contacts with Eclipse (methanol). I thought my problems were over but a few weeks later I noticed that something was rattling around loose inside the camera body. I didn't think much of it until I started having a problem where the DOF preview was randomly turning on and off by itself. I tried to see if I could remove the loose object by removing the battery and CF cards and shaking the camera but that did not work.
I did a little research and discovered a web-site where I could download the EOS 5D service manual that contained a complete parts list and full disassembly instructions. After reading the service manual, it became obvious that removing the camera body covers was pretty easy to do.
You should probably wear an anti-static wrist strap when working on any type of electronic equipment. I also recommend using an ice cube tray or something similar to keep the removed screws and small parts organized. You must be careful when reassembling to make sure a long screw isn't used where a short screw should go or you will probably ruin your camera's electronics.
The first step was removing the side cover (interface cover) using these steps:
1) Remove the BP-511 battery and the date/time button cell battery as described in the EOS 5D user manual
2) Remove the long black screw that's to the left of the short black screw that held the date/time battery case in place
3) Peel back the leather grip above the rubber flaps that cover the USB, remote shutter release, flash sync, and video out connectors
4) Remove the two long silver screws that are under the leather grip
Continued in next post...
Paul
Gear -- Flickr (external link)
shaftmaster
May 20, 2010 00:26 |  #2
5) Remove the short black screw on the left side bottom edge of the back cover
6) Gently lift the bottom left side of the back cover to allow the side cover to be removed
7) Remove the side cover (the leather grip tape will require some loosening along the left side near the flash sync and remote shutter release connectors)
Unfortunately, this didn't free the loose object inside the camera, so I continued the disassembly.
Paul
shaftmaster
May 20, 2010 00:29 |  #3
The second step was removing the back cover using these steps:
1) Remove the short black screw on the right side bottom edge of the back cover (the left side bottom edge screw was already removed)
2) Remove the eyecup by sliding it upward
3) Remove the two long black screws under the eyecup
4) Peel back the top right corner of the back cover leather grip
5) Remove the silver screw under the back cover leather grip
Paul
shaftmaster
May 20, 2010 00:34 |  #4
6) Gently pull back the rear cover (the leather grip tape may require some loosening near the top cover LCD panel). Be very careful to avoid tearing or kinking the two flex cables that connect the back cover LCD and controls to the internal PC boards. Once the back cover leather grip tape is detached from the top cover, lift the back cover from the top edge (viewfinder) as if the bottom edge was a hinge. This allows access to the flex cable connectors.
7) lift up on the darker part of the two flex connectors on the internal PC boards to release the two flex cables.
Continued ...
Paul
shaftmaster
May 20, 2010 00:37 |  #5
This is the back cover with the two flex cables:
At this point I was able to remove the loose object which happened to be one of the screws that was meant to hold one of the internal PC boards in place. I replaced the screw in its proper location and checked that the other screws were not coming loose.
Reassembly was pretty straightforward. The only thing to note was that the flex cables slide under the darker part of the flex connector until they can't be inserted any further, and then the darker part of the connector is pressed down to lock the flex cable in place.
Hope this information helps. It seems like replacement of the back LCD would be pretty easy.
Paul
shaftmaster
May 20, 2010 00:40 |  #6
Here's the EOS 5D with side and back covers removed:
The link to download the EOS 5D service manual is here:
http://store.payloadz.​com …-Manual-Repair-Guide.html (external link)
Let me know if you have any questions...
Paul
Omaru
May 20, 2010 01:10 |  #7
OH GOD PLEASE NO! :(
Visit my flickr (external link)
Visit my vimeo too! (external link)
Cosplay is Awesome
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
May 20, 2010 03:42 |  #8
Good work, and nicely documented! only thing I'd add would be the screwdriver size required - 00 Philips?
not a lot of use to you now, but there's also some useful tutorials on the lifepixel.com website that shows how to modify 5d's (among others) for IR working that would have also shown how to take the back covers off.
TF posting: here :-)
keithleeSTUDIOS
May 20, 2010 06:53 |  #9
Very cool! I wish there was a site where you could buy replacement OEM Canon parts online (like car parts).
Keith
Keith -
5DMKII + BG-E6|7D + BG-E7 + 580EX + 580EXII w/ difussers
Canon 17-40mm f/4L|50mm F/1.4|70-200mm f/2.8L MK1|100mm f/2.8 Macro Sigma 85 f/1.4
www.keithleestudios.co​m (external link)
alpha_1976
May 20, 2010 06:56 |  #10
Very nice. Thanks
I know more about gear than I know about photography :p
yuriyo923
May 20, 2010 07:03 |  #11
There is... it's called Canon! :)
Call canon parts line at 1866-481-2569
Chillybanana wrote in post #10214762 (external link)
Keith
Canon 5D2 ~ 40D + 17-50mm in da booth!
www.seattleboothrental​.com (external link)
shaftmaster
May 20, 2010 09:58 |  #12
joeseph wrote in post #10214412 (external link)
Yeah, probably a 00 Phillips head.
Thanks for the info about lifepixel.com. Here's a link to the 5D IR conversion that shows more pictures for disassembly:
http://www.lifepixel.c​om …nversion-instructions.htm (external link)
The 5D service manual is still nice to have since it contains much more information besides service and repair, plus it shows how to remove the front and top covers and pull everything else apart. This is required reading if you want to replace your own shutter assembly! :D
Paul
chammer
Joined Sep 2009
May 20, 2010 11:09 |  #13
I'm curious - How far would I have to get into this to get behind the viewfinder to clean dust from behind it?
flickr (external link) | My Site (external link) | My Gear (external link)
shaftmaster
May 20, 2010 11:31 |  #14
chammer wrote in post #10215884 (external link)
That's different, you clean the viewfinder and focus screen through the lens mount opening. There are instructions to do this for the 20D on the net somewhere. I might try doing it on my 5D.
Paul
chammer
Joined Sep 2009
May 20, 2010 12:53 |  #15
Yea, I've went through that way. I did a good cleaning when I got the camera this past weekend which included cleaning the mirror and focusing screen very carefully. However, the piece of plastic behind the eyecup has dust behind it (in addition to dust when looking through the VF). My goal is to take care of this myself versus sending it to Canon unless I have to. Mine still needs the recall service done, and I've been in touch with Canon. I was considering having them do the recall service, shutter replacement, and a complete cleaning of everything while they had it. However, knowing how to do a complete cleaning of everything myself would be handy.
21,657 views & 1 like for this thread, 16 members have posted to it.
1464 guests, 144 members online
