I have some compactflash and SDHC cards that I want to get rid of. However, I think I will need to securely wipe the memory cards in case someone tries to recover any images from the cards. How would I proceed to do that?
lsquare Goldmember 1,933 posts Likes: 2 Joined Apr 2008 More info | May 20, 2010 03:57 | #1 I have some compactflash and SDHC cards that I want to get rid of. However, I think I will need to securely wipe the memory cards in case someone tries to recover any images from the cards. How would I proceed to do that?
TweakMDS Goldmember 2,242 posts Likes: 1 Joined Nov 2008 Location: Netherlands More info | May 20, 2010 04:10 | #2 You can use one of these tools: Some of my lenses focus beyond infinity...!
Livinthalife Cream of the Crop 5,118 posts Likes: 1 Joined Jan 2006 Location: Austin,TX More info | May 20, 2010 04:14 | #3 formatting should do the trick. -Andy-
joeseph "smells like turd" More info | May 20, 2010 04:18 | #4 Livinthalife wrote in post #10214461 formatting should do the trick. just formatting won't do the trick.... there is untold file recovery softwares out there that will successfully recover every photo from a card that has "just been formatted' some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Livinthalife Cream of the Crop 5,118 posts Likes: 1 Joined Jan 2006 Location: Austin,TX More info | May 20, 2010 04:22 | #5 Well I guess that's good to know! I thought those file recovery programs only worked if someone only used the "delete all" function. -Andy-
DazJW Senior Member 319 posts Joined Jan 2010 Location: Teesside More info | May 20, 2010 04:24 | #6 My understanding is that deleting or formatting just marks areas of the disk free for writing rather than removing anything, so the only way to be sure is to fill the card with rubbish or completely destroy it.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | May 20, 2010 08:12 | #7 SD cards, unlike CF cards, support "low-level" formatting which only the most extreme measures might be able to recover anything from. Most file or picture recovery programs will fail at a low-level formatted SD/SDHC card. For a CF card, you'd need to completely overwrite the whole card (several times) to be reasonably sure you've zapped everything. Jon
May 20, 2010 08:35 | #8 lsquare wrote in post #10214431 I have some compactflash and SDHC cards that I want to get rid of. However, I think I will need to securely wipe the memory cards in case someone tries to recover any images from the cards. How would I proceed to do that? Grab a hammer and smash it Canon Stuff
ocabj Goldmember 1,120 posts Likes: 3 Joined Jan 2008 Location: Riverside, CA (USA) More info | May 20, 2010 09:04 | #9 Personally, I'd just reformat them. Write a bunch of random data to them, i.e. dd if=/dev/urandom of=/mount/point/for/cf and reformat them again. Jonathan Ocab - https://www.ocabj.net
FLiPMaRC Senior Member 967 posts Likes: 2 Joined May 2006 Location: NJ More info | May 20, 2010 09:24 | #10 ^ What they said. If you still want to go an extra step, you can download a free program ... CCLeaner
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | May 20, 2010 09:53 | #11 If you have a Mac, you can do it directly from Disk Utility. Doc Klepper in the USA
RayHff Member 111 posts Joined Dec 2009 More info | May 20, 2010 12:29 | #12 The only fast, sure fire way on any card is to destroy the card.
hfgarris Goldmember 1,760 posts Likes: 11 Joined Feb 2009 Location: Cedar Rapids, Iowa More info | May 20, 2010 13:33 | #13 If you have a Mac, use the secure erase of the built-in "Disk Utility". You can do a single or multiple over-write of all the data which will render the card "non-recoverable" for the original photo data files.
| Latest registered member was a spammer, and banned as such! 2716 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
