Thread started 20 May 2010 (Thursday) 10:42
Resizing Photos for sharing.
V-Wiz
Joined Sep 2009
May 20, 2010 10:42 |  #1
Fellas, what is the best way to resize photos for sharing on the Forums and emailing pics, because the file sizes are soo HUGE they need to be resized. Ive used Paint but thats not going to fly anymore. Thanks a bunch
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
tonylong
...winded
Gallery: 60 photos
May 20, 2010 10:52 |  #2
Just about any photo editing program makes resizing simple. You can do it in Paint, you can get little apps, or you can move to an app like Photoshop Elements that gives you more editing power than Paint and it also makes the resizing easy.
Each ap will have its own little method -- you just have to poke the numbers in and understand the options. A typical approach is to have the option to keep the aspect ratio intact checked, then for POTN you just enter 1024 pixels for the max size in each dimension. You also need to deal with jpeg quality levels, which may be in the same dialog or may be just through going through the Save As routine. If you are uploading from your computer to POTN you set the quality middle/low enough to keep within the 150KB file size. For other uses you set it to whatever works.
For the forum and other Web/computer display uses you can ignore the PPI figure -- it has to be something but only has meaning if you are calculating a print or graphical layout at a given size. For the Web and the screen the figure means nothing.
Hope that helps a bit -- if you have specific questions, let us know!
Tony
V-Wiz
Joined Sep 2009
May 20, 2010 10:56 |  #3
Tony, thank you for your help again, Ill have to look into all that. Question does the Canon software have this feature, im sure it would but i have not been able to find it and being busy i cant find time to dig into all that. Thanks.
tonylong
...winded
Gallery: 60 photos
May 20, 2010 11:29 |  #4
V-Wiz wrote in post #10215826 (external link)
Yes it does. In the Convert and Save dialog (and the Batch dialog) there are settings for both resizing the image and for setting the jeg quality. They are pretty simple to use.
Tony
Veemac
May 20, 2010 11:32 as a reply to  @ tonylong's post |  #5
If you're on a PC, Irfanview makes it dead simple - and it's free.
Mac
-Stuff I Use-
V-Wiz
Joined Sep 2009
May 20, 2010 11:52 |  #6
Thanks alot
shayneyasinski
May 20, 2010 11:56 |  #7
For quick resizing I select a batch then send to mail recipient and then pull them from the mail resized .
my gear Canon 7D, Canon 5DMK2, 70-200 f2.8 IS, 50mm f1.8, canon 430 speedlight, canon 17-55 2.8 IS, canon 100mm macro sigma 10-20, Canon 17-85 , 60 cokin filters , 2x telecoverter.
Sparky98
May 21, 2010 00:32 |  #8
Your Canon software DPP will do some basic editing and will resize your files also. Now that the latest version has a horizon leveling tool DPP is about all I ever use for PP these days and I rarely use my Photoshop Elements 8 anymore.
Joe
5DIII
RichSoansPhotos
May 21, 2010 01:17 |  #9
Why can't you use either DPP or elements?
886 views & 0 likes for this thread, 6 members have posted to it.
2531 guests, 170 members online
