New here; hope it's okay to ask a few questions that I couldn't find answers to.
1) Given two lenses of similar quality, both stopped down to the same aperture (e.g. f/5.6) for a particular shot, is there any advantage to having the "faster" lens (larger maximum aperture)? Or, is it just because faster lenses are usually of higher quality?
2) Is there any inherent advantage to a lens that uses 72mm (or 77mm) filters over a lens that uses 52mm filters? (Assuming the same sensor size, of course.) For example, on my T2i, if I had two 100mm f/5.6 lenses, would the one with the larger filter somehow gather more light through the f5.6 aperture? Or, are there other advantages to the larger filter size?
3) Possibly related to question #2, (again, with the same sensor size) do all lenses of similar focal length have similar field of view? Would every type of 50mm lens (on the same camera) produce an image with exactly the same boundaries? Would a 50mm prime lens have the same field of view as my 18-55mm zoomed to 50mm? Or, would an 18-270 also have that same field of view when zoomed to 50mm?
Thanks - I really appreciate any help with these questions.
