Thread started 22 May 2010 (Saturday) 05:43
which extension tube?
jabber
May 22, 2010 05:43 |  #1
I try to limit my travel kit to my Canon 40D and 17-55/2.8. I'd like to bring along an extension tube for occasional close-ups, too. For that camera/lens combo, which makes more sense: the 12mm or the 25 mm?
40D, 10-22/3.5-4.5, 17-55/2.8 IS, 70-200/4L, 60/2.8 Macro, 85/1.8, 1.4x II Extender, Lensbaby Composer
"You can't wait for inspiration. You have to go after it with a club." -Jack London
Wilt
May 22, 2010 10:22 |  #2
12mm, unless you are into true macro range.
12mm tube on 50mm FL = about 0.25x lifesize (20mm object is 5mm on 15mm frame height)
12mm tube on 31mm FL (APS-C 'normal' FL) = about 0.4x lifesize
halitime
May 22, 2010 12:00 |  #3
A set of Kenko tubes costs about the same as a Canon 25mm tube and then you have three to choose from.Also I believe a tube will allow you to mount your TC to some of the lenses it will not fit on now
for added "magnification"
Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
http://www.flickr.com/​photos/halitime/sets/ (external link)
ocjohn
May 24, 2010 04:17 |  #4
The newer Kenko tubes are EF-S compatible. Adorama didn't specify which version it was when I boutht at the end of last year, but EF-S OK.
Kolor-Pikker
May 24, 2010 06:52 |  #5
I have the Kenko set and recommend it too. 3 rings really help as different lenses and situations might require different amounts of extention.
Build quality is good enough for anything you might throw at them.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
Jannie
May 24, 2010 10:55 |  #6
I use the Canon 12mm a lot on my 24-70, I use the 25mm on long lenses like the 70-200 and 100-400. Rarely have I ever used the 25 on anything shorter than 85mm.
Ms.Jannie
"When you come to a fork in the road, take it"!
1DMKIII, 85LII, 24-70L, 100-400L
1,528 views & 0 likes for this thread, 6 members have posted to it.
1747 guests, 172 members online
