Thread started 23 May 2010 (Sunday) 14:07
Primos-Bi-Pod-Trigger-Stick for quick subject acquisition doing Macro/ Wildlife
GAJoe
Gallery: 23 photos
May 23, 2010 14:07 |  #1
Thought I'd share a new accessory I've discovered that helps with quick acquisition of your subject. It's called the "Primos-Bi-Pod-Trigger-Stick". When I saw that the unit was equipped with a removable V-yoke that revealed a combo 1/4"-20/ 3/8"-16 thread fixture screw like my tripod I knew it's potential for my macro photography. Here's a link to the device:
http://www.amazon.com …rd_r=0DAN1R0Y3R​ZMFGWG8WE8 (external link)
Here's my set-up using it in combination with my S5 IS and DCR-250 sitting on top of my Manfrotto 322RC2 grip action ball head:
IMAGE: http://i9.photobucket.com/albums/a93/GAJoe/IMG_4230.jpg
It comes in Short and Tall models; I got the short one becouse my demands for fast work are usually waist high and lower while doing macro photography.
The really neat feature of this bi-pod is that the legs heights adjusts quickly and independently with a simple pull and release of the trigger. Note that the legs are independent, so you can use it on uneven ground and maintain a level and steady camera. The only movement is toward and away from the subject, which I need for focus anyway. Here are a couple of images from my first trip out with it this morning:
IMAGE: http://i9.photobucket.com/albums/a93/GAJoe/IMG_7216.jpg
IMAGE: http://i9.photobucket.com/albums/a93/GAJoe/IMG_7196.jpg
I should tell you that the first unit I got didn't work properly and had to return it for replacement. I haven't had it in the field much yet also to know how they hold up. The reviews on the website don't indicate a problem. Hope this helps you as I can tell it helps me.
Joe
Canon R5, 7D Mk II, EF 100-400L MkII, EF 1.4X III, EF-S 18-135mm STM, 430 EX II flash, DCR-150, DCR-250, MANFROTTO 055XPROB w/ 322RC Grip
1,063 views & 0 likes for this thread.
2725 guests, 151 members online
