Thread started 23 May 2010 (Sunday) 20:47
Light Cycling
JoePhotoOnline
May 23, 2010 20:47 |  #1
Beginners talk about cameras, Pros talk about lenses, and Masters talk about light.
Feedback: 1 2 3 4 5 eBay UserID: 1969fordtruckman
JoePhotoOnline
May 23, 2010 20:48 |  #2
Manual exposure and WB. Only difference between shots is the park lights cycling.
SkipD
Joined Dec 2002
May 23, 2010 20:55 |  #3
Gas discharge lighting changes intensity and color at twice the rate of the power line frequency. This is because the voltage is cycling from 0 volts to maximum 120 times per second in the US and at 100 times per second in places using 50Hz power. This is an often-seen thing with fluorescent lighting.
When using gas discharge lighting and a shutter speed faster than 1/120 second (or 1/100 second where the power line frequency is 100Hz), the images can easily look different from one to the next, both in intensity and color.
Skip Douglas
JoePhotoOnline
May 23, 2010 20:59 |  #4
SkipD wrote in post #10233593 (external link)
Thanks SkipD. I knew that, but I was just sharing this graphic I made so that others could be aware about it. Thank you for the description.
SkipD
Joined Dec 2002
May 23, 2010 21:15 |  #5
JoePhotoOnline wrote in post #10233617 (external link)
Can you slow down the cycling of the images so folks can see the differences better? Five to ten times the delay would be good in my opinion.
Skip Douglas
JoePhotoOnline
May 23, 2010 21:25 |  #6
Sure. I'll see if I have another example that would also be a longer shot sequence
neilwood32
May 24, 2010 07:33 |  #7
A very good example of how the cycling of lighting can affect the images.
And also a good example of where RAW comes to the rescue - all the shots can be recovered to the "correct" WB with a few simple clicks with no IQ loss at all.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
SkipD
Joined Dec 2002
May 24, 2010 08:53 |  #8
neilwood32 wrote in post #10235548 (external link)
This is not quite true, at least with the photos presented in the demo.
If you look carefully, the background is lit and colored the same way for all of the shots in the series while the foreground changes from shot to shot. This is because the entire image is not lit with the same source. The background is natural lighting and the foreground is lit with the stadium's lights. This makes for a very difficult job of correcting the images to have them all look the same.
Skip Douglas
neilwood32
May 24, 2010 11:48 |  #9
I see what you mean - the deep background outside the fence is "lit" by ambient light or the lack of it. However within the fence, it appears to be lit evenly (hard to tell at the rate of the frames).
I did a quick try within PSP (only package I have at work) and altering WB did not affect the background by any noticable amount (due to the darkness of the areas).
806 views & 0 likes for this thread, 3 members have posted to it.
Light Cycling
2529 guests, 169 members online
