Thread started 23 May 2010 (Sunday) 21:49
Tripod Upgrade?
ayee007
May 23, 2010 21:49 |  #1
I bought a standard 53" Dynex Tripod back when I first got my t1i.
http://www.bestbuy.com …6&loc=01&id=119​6470448706 (external link)
I've used it to shoot with the kit lens and 50mm f/1.8 with great results. I recently purchased the 70-200mm f/4L and want to know if simply buying a tripod mount ring and using this tripod would work...or if i should get a more sturdy tripod to support the weight? if you think i should upgrade, can you give me recommendations on what to get without breaking the bank? thanks!
JohnJ80
May 23, 2010 22:10 |  #2
Actually you would benefit from both a tripod ring and a better tripod. You can buy the chinese knockoff rings cheap on ebay but do spend an appropriate amount to get a decent tripod. I don't know how to say this nicely, but your current tripod is in the "junk" category. It's primarily designed for home videos and consume video cameras.
While Canon doesn't supply a ring standard on the lens, it's just a much better idea to balance the camera and lens mass on the tripod rather than cantilever it out from the tripod mount on the camera body. I always shoot mine (f/4 IS) from either a monopod or a tripod using a ring.
Here's some tripod reading for you:
http://bythom.com/supp​ort.htm (external link)
http://www.luminous-landscape.com/essays/t​ripods_&_heads.shtml (external link)
http://markins.com/cha​rlie/report4e6.pdf (external link)
Both that 70-200 f/4 and the 50mm will perform very well when you give them a good stable base.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
ayee007
May 23, 2010 22:21 |  #3
thanks john for the reply. i couldnt make out what you were saying from your middle paragraph...i should upgrade with a better tripod and also get the tripod mount ring for the lens...
yea the tripod i have is as basic as it gets and its given me exactly what i paid for it, but im just not an expert in tripods, so i wouldnt know what tripod really is the best bang for the buck...
thanks again for your help!
JohnJ80
May 23, 2010 22:33 |  #4
Tripods are tough. There are no industry standards or common testing methods. There are also a lot of knockoffs that look great but have less than stellar performance. Gitzo's top of the Line, Feisol is a good cheaper alternative. Manfrotto is a solid manufacturer of tripods although typically not light weight. In general, expect to pay what you'd pay for a decent lens for the tripod/head combination especially if light weight is a concern.
What I was saying up above is that if you mount your camera and lens by the base of the camera - you are hanging all that weight out on the end of a big lever. That's going to be more prone to problems with vibration (i.e. softness) than is the whole thing mounted by a tripod ring.
J.
Obsessive Gear List
ayee007
May 23, 2010 22:40 |  #5
thanks john. yea i need a tripod ring for sure...im looking at the optika ring off amazon for the 70-200 f4. dont want an ebay knockoff to malfunction and my 70-200 and t1i end up on the ground...
for an amateur shooter whos just getting to know the ropes of photography, i dont think i can justify paying 200-300 for a tripod, but i do know that i need one that can deliver images with great quality
tvphotog
May 24, 2010 08:30 |  #6
ayee007 wrote in post #10234097 (external link)
In that case, get an inexpensive Manfrotto aluminum tripod and the 496RC2 head. Check them at B&H online.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
JohnJ80
May 24, 2010 09:45 |  #7
THe Manfrotto Aluminum is a good suggestion. The rule of thumb is that tripods can be cheap, stable and lightweight - pick any two but you can't get all three. Stable, heavy and inexpensive means Aluminum and will perform great. I think it's the Manfrotto 3021 (or there might be a new model number for that).
J.
Obsessive Gear List
cheerio
May 25, 2010 11:51 |  #8
stay away from those knockoffs
ayee007
May 25, 2010 16:49 |  #9
yea i will...i cant afford a canon ring, but is the optika a good replacement? i figure i go with a brand that actually makes canon product replacements...
Brain ­ Mechanic
May 25, 2010 17:01 |  #10
I went with this one...
http://www.bhphotovide​o.com …ro_780DX_Tripod​_with.html (external link)
Gear: a toothed wheel :p
--Oscar--
JohnJ80
May 25, 2010 17:10 |  #11
I mean, tripod rings aren't exactly rocket science. It's really not worth a lot of thought.
J.
Obsessive Gear List
ayee007
May 25, 2010 17:16 |  #12
JohnJ80 wrote in post #10245093 (external link)
J.
very true, but get a bad one and 1K worth of gear is smashed!
tattooDan
May 25, 2010 17:23 |  #13
ayee007 wrote in post #10233853 (external link)
this thread helped me a lot,good info from smart people here.
https://photography-on-the.net/forum/showthre​ad.php?t=872250
I ended up spending $275,but in the long run and investment in lenses,it's good with me. :)
JohnJ80
May 25, 2010 17:36 |  #14
ayee007 wrote in post #10245126 (external link)
It's pretty obvious if it's a good one or a bad one. It's just a metal ring with a nut on it. Definitely can overthink this one.
J.
Obsessive Gear List
ayee007
May 25, 2010 17:38 |  #15
tattooDan wrote in post #10245159 (external link)
thanks for the ideas!
2,335 views & 0 likes for this thread, 8 members have posted to it.
Tripod Upgrade?
2721 guests, 151 members online
