Thread started 24 May 2010 (Monday) 00:31
My impressions of the 7D (a.k.a. why I upgraded yet again)...
kcbrown
May 24, 2010 00:31 |  #1
A few days ago, I bought a 7D.
Yeah, I know. I already have more camera bodies than I know what to do with. So why'd I do it?
I can summarize it in one sentence: this is the first camera body that Canon has ever produced that has no real weaknesses (except for the crop sensor versus full frame sensor thing).
Allow me to elaborate a bit.
I bought the 30D as my first body (my wife now shoots with it). Its image quality is good, but I wasn't terribly impressed with the autofocus system. The center point is good, but the surrounding points leave quite a lot to be desired. Because they're not "cross type", they couldn't lock onto certain subjects.
So I upgraded to the 40D, both for the better high-ISO performance and for the autofocus system. On paper, the 40D's autofocus system is good. In the real world, it's merely okay. At least, it was for me. I never really got the reliability I wanted from it, even when shooting still shots (don't get me wrong -- it's not bad -- it would get it right most of the time, but for still shots, my opinion is that the autofocus system should get it right every time, because the conditions aren't changing). At least live view could be used for those when it really counted. Servo tracking was also hit-or-miss, mainly because it behaved as if it had too much caffeine. Finally, I had an issue with it consistently misfocusing at distance with wide aperture lenses (f/1.4). It took two trips to Canon to get that last thing fixed, but the other two things never improved much.
While it was on its second trip to Canon, I rented a 50D. This yielded a noticeable improvement in terms of autofocus. Still shot autofocus was finally sufficiently reliable for my purposes. And despite claims to the contrary, its high ISO performance was noticeably better than that of the 40D. And, at last, I could adjust the camera to my lenses! Because of that, and because I wasn't convinced Canon would be able to fix the focus issues of my 40D, I bought one. Its high ISO shots yielded some banding, but I got software to deal with that (for the most part). The 50D isn't a perfect camera, but it's very good.
But not perfect. For instance, servo tracking is easily disturbed by objects passing in front of the subject being tracked. And the autofocus points are quite a bit larger than the size of the points in the viewfinder would suggest, so the camera can easily lock focus onto something other than what you intended. And then, of course, there's the high ISO banding which, as I said, isn't that much of an issue with the right postprocessing software. But you do have to go out of your way to fix it.
A few days ago I borrowed a 7D from a friend because I wanted to see just how good it was. In this case, I borrowed it with an extremely skeptical eye. I looked very hard for any significant weaknesses, anything that would give me reason to wait until the next generation.
And I didn't find any.
Needless to say, I was very surprised. Up until now, Canon has always left at least one significant weakness in their "prosumer" cameras.
You see, what I really want is to buy a camera that is so good that it leaves me wanting nothing. Except for the lack of a full-frame sensor (and the benefits to be had from that), the 7D is that camera.
This is the crop camera that Canon should have been producing to begin with!
Its high ISO is relatively clean. It's not actually all that much better than what the 50D gives you, but it doesn't have a banding issue. ISO 12800 is now quite usable, particularly if you shoot in mRAW, which gives you a very usable 10 megapixels -- exactly the same as what you'd get from the 40D.
Its autofocus system is reliable. It nails the focus for still shots pretty much every time, with any of the autofocus points. Its servo tracking is reliable and, finally, configurable for the circumstances. And it at last is capable of focusing on a precise spot in the frame if you want to configure it that way.
The viewfinder is magnificent. It's big and bright. A full frame viewfinder is bigger and brighter, but this is actually good enough that you can manually focus with it with some reliability. So for the first time, I'm not inclined to change the focusing screen (as it happens, though, changing it out apparently isn't all that hard, though it's obviously more involved than changing out the 50D's screen). And having 100% of the view in the viewfinder is the way it should have been from the very beginning.
I'd read complaints about low ISOs being noisy. My tests showed the 7D's ISO 100 to be at least as good as that of the 50D.
When I add everything up, the 7D leaves me wanting nothing except a full frame sensor. And perhaps not even that. I won't really know how much a full frame sensor will buy me until I borrow or rent a camera with such a sensor, and Canon doesn't yet make a reasonably priced camera that suits my full-frame needs (to wit, they don't make anything that competes head to head with the Nikon D700).
So I must congratulate Canon. Because at long last, they've managed to produce a camera that does everything well and leaves me wanting nothing more out of a crop camera body, and all for a non-stratospheric price.
It's about time.
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
Canon: 2 x 7D, Sigma 17-50 f/2.8 OS, 55-250 IS, Sigma 8-16, 24-105L, Sigma 50/1.4, other assorted primes, and a 430EX.
Nikon: D750, D600, 24-85 VR, 50 f/1.8G, 85 f/1.8G, Tamron 24-70 VC, Tamron 70-300 VC.
L.Morey
May 24, 2010 00:38 |  #2
Great review
7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
Sigma 150-500 , Sigma 18-200f4-6.3 , Canon Ste2 , Canon
580mki , Canon 580mkllx2
http://lwmorey.zenfoli​o.com/ (external link)
tpatana
May 24, 2010 00:45 |  #3
Why ISO12800 would be better on mRAW? Care to explain?
Have: Many cameras with some Ls
Kendo.Photography (external link) / Kendo@Facebook (external link) / TeroPhotography.com (external link) / Tero@Facebook (external link) / CF card Speedtest on my gear (external link)
shedberg
May 24, 2010 01:02 |  #4
My friend asked me if there was anything I didn't like about my 7D. I thought long and hard, but couldn't come up with a single thing. I'm very happy with it.
6D / 7D / 16-35 II / 35 2.0 IS / 60 macro / 85 1.8 / 135 2 / 100-400 / 430EX II
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
May 24, 2010 01:05 |  #5
tpatana wrote in post #10234584 (external link)
By virtue of reduction in resolution/image dimension, the noise level is also reduced. Reading through the OP's post, it seems that 10mp is sufficient for his use and shooting the 7D @ iso12800 at 10mp gives him usable images.
Julian
shedberg
May 24, 2010 01:18 |  #6
jwcdds wrote in post #10234649 (external link)
Holy cow it works. :O
Thanks so much for the tip! :)
CH_Devin
Gallery: 12 photos
Joined Sep 2009
May 24, 2010 01:25 |  #7
I borrowed one from a friend to use, and the only thing that bugged me was the noise at low ISO. It bugged me enough to keep my 50D, but not enough to stop me from wanting a 7D in the end.
shedberg
May 24, 2010 01:28 |  #8
CH_Devin wrote in post #10234705 (external link)
Strange as it may sound, if you process the RAW file with DPP instead of ACR, the images come out a lot cleaner.
soundwave888
May 24, 2010 01:29 |  #9
noise @ low ISO eh? how low are you talking about? i've only read about high ISO noise
dinanm3atl
May 24, 2010 01:30 |  #10
Nice... about to drop the hammer on one.
Halston - MotorSports Photographer
1Dx - 1Dx - A7r - 400L f/2.8 - 70-200L f/2.8 - 24-105L f/4 - 17-40L f/4 - 50 f/1.4 - 8mm f/3.5 Fisheye - 1.4x TC - 2x TC
Photography Site (external link)
shedberg
May 24, 2010 01:42 |  #11
soundwave888 wrote in post #10234718 (external link)
It's true. I was NOT IMPRESSED with image quality when I first got my 7D. Then I noticed that jpegs were coming out of the camera A LOT CLEANER than the images I could get from the RAW files through ACR, even at low ISO. I read around on a few different sites and they all suggested using DPP for RAW files instead of ACR, and when I switched I immediately noticed that my images looked way better.
It adds an extra step to my processing, but it's worth it in the end.
kcbrown
May 24, 2010 01:52 |  #12
Did you reduce the size of the low ISO files to 15 megapixels (that is, same dimensions as those of the 50D you were comparing against)? If not, then it wasn't a completely fair comparison.
That said, I compared ISO 100 shots at 100% from both the 7D and the 50D after being converted with ACR version 5.6 (not the beta version) and still didn't see a noise issue. As in, I saw no noise in one shot that I didn't see in the other.
I did notice with an older version of the firmware that the mRAW ISO 100 shot showed some subtle vertical banding in the shadows, but I haven't retried the experiment after I got my 7D (which has firmware version 1.2.1). All that really told me is that if I want to shoot at ISO 100, I should do so at full resolution (which didn't show that problem at all).
Like I said, I did my testing while looking for any reasonable excuse to pass over this body, and found nothing. In a way, I don't expect Canon to ever really do that again anytime soon. Canon's not known for hitting them out of the park, so I figured I should get one of these "home run" cameras new while it's still possible to do so. :-)
tpatana
May 24, 2010 01:56 |  #13
I'd agree if the pixels, or the capture area were larger.
But the RAW resolutions for 7D are:
- RAW = 5184 x 3456
- MRAW = 3888 x 2592
- SRAW = 2592 x 1728
So the middle one simply takes the full resolution picture, and interpolates new resolution. There's no way it can have better ISO performance, as there's no "extra" light for anything.
For sRAW I could believe the explanation, as it can use 4 real pixels for each output pixels, so that can be used to capture more light (4x more) and average to remove noise for each output pixel.
Now I think it few times through, actually they can use the same averaging for mRAW too, so I guess it does help, although I think the sRAW would be even better.
shedberg
May 24, 2010 02:03 |  #14
tpatana wrote in post #10234783 (external link)
- RAW = 5184 x 3456
I just ran a quick & dirty test of ISO 12800 on RAW and mRAW... no NR, converted both to jpeg in DPP with identical settings, and the mRAW picture actually looked a little better IMO.
tpatana
May 24, 2010 02:32 |  #15
shedberg wrote in post #10234790 (external link)
Would you mind running also sRAW? I'd guess it'd be even better.
4,904 views & 0 likes for this thread, 16 members have posted to it.
1432 guests, 109 members online
