Thread started 24 May 2010 (Monday) 12:13
Something in my light is off...
TweakMDS
May 24, 2010 12:13 |  #1
(UPDATE: new pics below)
Hey all,
I was putting together my macro flash-bracket set this weekend and just found a bee at work on a flower in my backyard. It wasn't too bothered with me as long as I the flash (paper towel) diffuser out of blocking the sun.
I use a bracket, ballhead and off shoe cord, but compared to some of the other shots I see here, something seems off with mine... is it the directional light? Is it my post processing workflow? Am I expecting too much? Could use some help with this...
Here's the shot in question, shot with a 40D, Canon 100mm macro, F/14, ISO 160, 1/250th.
IMAGE: http://farm5.static.flickr.com/4042/4636228834_4e85afd9ed_b.jpg
Here's another shot right before it, where the flash is turned to the side a bit more, only it was blocking the sun from the bee, so I moved it a bit more to the back / towards the lens. I prefer the look of the second image, but unfortunately my angle and the composition are FUBAR ;)
IMAGE: http://farm4.static.flickr.com/3362/4635643353_044fac5ea2_b.jpg
Some of my lenses focus beyond infinity...!
~Michael
Gear | Flickr (external link)
"My featured shots" (external link)
LordV
May 24, 2010 14:27 |  #2
Apart from the oof foreground in both shots, the lighting does not look bad to me. The images are a little soft but assume that is diffraction softening from shooting at F14 ?
Brian v.
Macro Hints and tips
motleypixel
May 24, 2010 14:31 |  #3
Brian's thought seem logical. Try different settings...i.e. move the light closer, reduce shutter a bit, lower aperture a bit. Just try different setups and test using inanimate objects such as lego people :)
Minolta Rokkor and Canon can live together in harmony. (external link)http://vimeo.com/14891​384 (external link)
TweakMDS
May 24, 2010 15:03 |  #4
F14 could be a problem, one of the earlier shots was at F11, which looked better, although I thought I had some more breathing space (up to like F16) until diffraction became noticeable.
I'll try to get a different angle to get rid of the foreground as well, good suggestion :)
~Michael
TweakMDS
May 27, 2010 07:29 |  #5
I was able to give it another go today :)
This time I got the able and the aperture ok, but due to technical limitations (of the ballhead + cactus receiver), I wasn't able to get the light close enough. Decided to order a lumiquest mini softbox rather than keep using paper towels. I also have to fiddle with my bracket to get the flash lower (or higher and aim it across from the other side).
I also used another flash this time, my Nikon SB-28 which has a bit more power and WAY faster recycle than my Metz 36 (Canon TTL) flash. On the down-side, I didn't have my sync cord with me so had to use it with a wireless receiver which messed with the height.
Still a work in progress, but I'd still like to show you guys :)
Any other critique / comments?
These were all shot at 1/200th, F11, ISO 160, manual flash at 1/2 power and some had -0.33 stop FEC (on the flash itself).
Full size versions are on my photostream (external link).
#1
IMAGE: http://farm5.static.flickr.com/4053/4644742118_363d07437e_b.jpg
#2
IMAGE: http://farm4.static.flickr.com/3404/4644126135_ffb38b0899_b.jpg
#3
IMAGE: http://farm5.static.flickr.com/4024/4644744138_90a08e51a3_b.jpg
Thanks for looking :)
~Michael
LordV
May 27, 2010 07:36 |  #6
Looking good - perhaps a bit more diffusion needed- you may get this with the mini softbox
Brian V.
TweakMDS
May 27, 2010 07:47 |  #7
LordV wrote in post #10254782 (external link)
Brian V.
Thanks Brian :)
I agree - definitely more diffusion needed. This diffuser is crappy and it had to be higher than I wanted it to because of the wireless transmitter. If I use a pc cable it'll be closer already.
And indeed - it's either a mini softbox or a "LordV ghetto-style coke can diffuser", and I am scared to cut myself on the can :D
The mini softbox is slightly more portable though, and I basically bring my entire rig to work every day, so portability is required.
~Michael
annainoz
May 28, 2010 10:48 |  #8
Well you've blown me away with these amazing photos. Seeing what a camera and lense is capable of is gobsmacking.
Canon EOS 50D, 18-200mm, 50mm 1.8
On my DSLR L plates My Flickr (external link)
spidermanrbryce2006
May 28, 2010 17:42 |  #9
some good shots, like the second shot the best tho
Bryce McQuillan A.K.A Spidermanbryce2006, New Zealand (Hamilton)
Nikon D50/D90/60mm macro/Sigma 70-200 F2.8/18-55 Canon 50D/MPE-65/MT-24ex,
http://www.flickr.com/​photos/spidermanbryce2​006/ (external link)
spidermanbryce2006@hot​mail.com (external link)
TweakMDS
May 29, 2010 09:25 |  #10
Thanks for the comments and encouragement :)
I processed another out of the second set with a little different than my usual workflow, wonder what you guys like better:
IMAGE: http://farm5.static.flickr.com/4002/4649366149_359f9afe10_b.jpg
~Michael
2,085 views & 0 likes for this thread, 5 members have posted to it.
1487 guests, 187 members online
