Is it possible to use autofocus and time delay at the same time?
dandavis Junior Member 26 posts Joined Dec 2009 More info | May 26, 2010 14:47 | #1 Is it possible to use autofocus and time delay at the same time?
crashthenet44 Senior Member 514 posts Joined Mar 2009 Location: Rails of the Lehigh Valley Line and Trenton Sub More info | May 26, 2010 15:20 | #2 time delay? FLICKR
tonylong ...winded More info | May 26, 2010 15:24 | #3 Sure -- pushing the shutter button half way (or the AF rear button if you have that set up) will still activate the AF and if you have a subject in postion you can focus, then fully depress the shutter button to activate the timer. Tony
May 26, 2010 15:33 | #4 Yes-first select the timer delay on the "drive" 2 sec or 10 sec,half press the shutter to activate the AF, when focus is achieved then fully depress the shutter to start the timer. Chris
birdfromboat Goldmember 1,839 posts Likes: 1 Joined Mar 2008 Location: somewhere in Oregon trying to keep this laptop dry More info | May 27, 2010 17:18 | #5 get a remote trigger device. The POTN shop has a nice one for cheap. servo mode, hold the antennae out of the shot or remove it in post, click away. 5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
| Latest registered member is IoDaLi Photography 1826 guests, 114 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
