I started this thread on another board...but I like this board it moves a bit slower then the other. I figured I would mirror the question here. What is everyone doing for a standard workflow with the D30. My workflow to date with the D30 (brand new only got it last week) consists of using breezebrowser to export to .tiff 8bit or 16bit. I still haven't made up my mind on whether I want to stick with 16bit for the size at this point. I usually use white balance auto, saturation high, sharpness low and contrast low. I then open in PS with Fred's D30 ICC and convert to RGB workspace. From there I usually use Levels to make a few adjustments...I will play with curves if need be. I am still looking for a really good sharpening technique I think the thread here on that is very interesting. At that point if it is web I will res to 72dpi and the size I want. If it is print I will res to 360 dpi and the size I want to print. I plan on letting my raw files build up to 600 MB or so then using breezebrowser renumbering feature to renumber consecutively then burning to CD.
Interested to see what everyone else was doing for as standard workflow.
