I need something that gives me the most light coverage. Are those globe diffusers available for our speedlights?
FellipedePaula Senior Member 438 posts Joined Jan 2008 Location: Brazil More info | May 28, 2010 16:35 | #1 I need something that gives me the most light coverage. Are those globe diffusers available for our speedlights?
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | May 28, 2010 16:43 | #2 |
Zansho "I'd kill for a hot pink 40D" More info | May 28, 2010 16:45 | #3 Get an empty gallon milk (or water) jug, cut it to fit your speedlight, and voila! Instant diffuser that does the same work as a Gary Fong diffuser! http://www.michaeljsamaripa.com
May 28, 2010 16:51 | #4 krb wrote in post #10263462 Yes they are available, but are you sure that's the best solution? Yes... I'm into 360º panos and I need the most coverage I can since my sigma 8mm covers 180º
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | May 28, 2010 17:50 | #5 |
loveworks Member 48 posts Joined Jan 2007 More info | May 30, 2010 16:30 | #6 Bulk Soup containers work great too. Go buy a couple pints of wonton soup and you're good to go.
YeahImJosh Member 234 posts Joined Aug 2009 Location: Toledo, Ohio More info | May 30, 2010 17:41 | #7 Gary Fong?
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Large wonton soup container. IMG NOTICE: [NOT AN IMAGE URL, NOT RENDERED INLINE] Robert
CxThree Senior Member 713 posts Joined May 2009 More info | May 30, 2010 23:14 | #9 Just get a stofen omnibounce. Just as effective if used correctly and you don't look like a tool. Canon EOS 5D MKIII, 7D
ecub Goldmember 1,487 posts Joined May 2010 Location: Southwest suburbs of Chicago More info | Jun 01, 2010 15:51 | #10 CxThree wrote in post #10274135 Just get a stofen omnibounce. Just as effective if used correctly and you don't look like a tool. ![]() You embarrassed using a plastic milk carton taped to your flash when your shooting weddings? - Ed
dmward Cream of the Crop More info | Jun 01, 2010 16:32 | #11 If you go with the Omnibouce or its knock offs, cut the front out of it. David | Sharing my Insights, Knowledge & Experience
CxThree Senior Member 713 posts Joined May 2009 More info | Jun 01, 2010 17:10 | #12 ecub wrote in post #10283747 You embarrassed using a plastic milk carton taped to your flash when your shooting weddings? Correct. Canon EOS 5D MKIII, 7D
| Latest registered member is ANebinger 1022 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
