Thread started 28 May 2010 (Friday) 22:53
When Will I Love IS?
mitchman
May 28, 2010 22:53 |  #1
I needed to shoot a commercial shot of a small piece of plumbing in our studio. This was the first time I had shot with our new 70-200 f/2.8 IS II. First I shot hand held and even though the shutter speed was 1/500th, the photo had motion blur. So then I put the camera on our tripod and took some more shots. No luck...still blurry. I couldn't figure out what was going on. But then it dawned on me....turn off the IS. Bingo. Clear photo.
So I know everyone says that IS is good. But is it only for handheld shots? Does it turn a shot that would normally be really blurry into one that's only a little bit blurry? Or can I some how actually get some sharp photos with it turned on?
I know that as I took more and more photos I would figure this out for myself, but I thought maybe someone would help with some advice. :)
5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
3 x 580EXII's, PocketWizard FlexTT5's, AC3 Zone Controller, Westcott Apollo softboxes www.focalpointmarketin​g.com (external link)
mike_d
May 28, 2010 22:57 |  #2
Yes, most lenses need you turn off the IS when you use a tripod or it'll actually add blur. How much coffee do you drink? That 1/500' shot should have been pretty sharp. Were you running up against the minimum focusing distance or moving closer/farther from the subject with a narrow DOF?
gjl711
May 28, 2010 23:11 |  #3
mike_d wrote in post #10264918 (external link)
That was for gen-1 and gen-2 IS, the IS in the 100-400 and 28-135. The later IS versions, the one in the 70-200s have tripod detection.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
crn3371
May 28, 2010 23:13 |  #4
Wow, motion blur at 1/500 with that lens? Time to switch to decaf.
gjl711
May 28, 2010 23:19 |  #5
Motion blur at 1/500 is pretty bad. Figure an object moving at 60MPH will only move 2 inches at 1/500.
::Gear::
Dereksalem
May 28, 2010 23:37 |  #6
A few things...
The 70-200 f/2.8L ISs (both versions 1 and 2) have Tripod Detection...the IS would have automatically shut off. That eliminates the IS being the major source of blur in that shot.
Secondly...at 1/500 of a second there should be *NO* blur what so ever in your shots unless you are carrying a blender in your other hand and it's dicing tomatoes. At 200mm most people should be able to take a shot at 1/200 without noticeable blur.
Going to hazard a guess and say there's something wrong with the copy you got.
jdizzle
Darth Noink
May 28, 2010 23:42 |  #7
That is odd. 1/500 is a decent SS to capture some plumbing work. If you weren't within the MFD then I could see that being a problem. If you're hands aren't steady then I blame the user. :) If it's new then you could have an issue with the IS motor or have a defective lens.
jdizzle
Darth Noink
May 28, 2010 23:48 |  #8
I did a test with the IS when I first got the lens and it works like a charm.
https://photography-on-the.net …35&highlight=st​eady+hands
newworld666
May 29, 2010 00:38 as a reply to  @ jdizzle's post |  #9
over .. 135mm ...daytime, my standard speed is 1/800 :confused: .. it's almost the only way to nearly freeze, hands, feets, fingers, car lights, birds, dogs ..
70-300DOIS seemed to be working rather well, but I always got sharper pictures with an appropriate speed, rather tha a low speed and IS.. So since I sold it, I don't miss IS, even if now for candids in town I use a zuiko 500mm handheld fixed on 1/1000 F8 :D ... just iso are automatic.
:rolleyes: I never understood why people daytime, prefered low speed and low iso with IS than appropriate speed with appropriate ISO without IS.
On my side I gave up to use IS .. and sold my zooms too...
I dream that one day canon's body would reach nikon's capability to reach perfect noiseless high isos meanwhile I use noiseware.
Marc
5DMKII+1Dx 24L1.4II 85L1.2II 180L3.5 300F2.8nonIS TC2XII ..... Sigma14F2.8AFDG, Zuiko 500F/8 Reflex
http://myc-photos.eu (external link)
iadubber
May 29, 2010 07:38 |  #10
You should cut all ties with the lens and just send it to me.
Buyer/Seller Feedback
mitchman
May 29, 2010 09:44 |  #11
Thanks for the comments guys. (no I'm not a coffee drinker) :)
Just to be clear:
1) I first tried shooting handheld w/IS - got motion blur
2) Then I used a tripod w/IS - got motion blur
3) Then with the camera still on the tripod, I turned off IS - sharp photo
The piece of plumbing was black plastic on a white background, shot in studio with studio lighting.
I'll confess....I'm not positive it was shot at 1/500th of a second. I shot this at work 1-month ago and I need to go back and check what shutter speed I was actually using.
Overread
Gallery: 12 photos
May 29, 2010 09:53 |  #12
Dereksalem wrote in post #10265088 (external link)
A few things...
You sure? I've got blurry shots from tripod shooting from when I had the IS on. I suspect its a case that "tripod shooting" is a hairtriggor thing whereby if the IS detects no noticable motion it shuts off, but if it thinks it does it keeps going - it might also be that it needs a moment of running time in order to detect and then shut off (and then of course that will only be valid for that shot/burst of shots and as soon as you lift up off the shutter the process starts again).
Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Tamron 24-70mm f2.4, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
My flickr (external link)
Amamba
May 29, 2010 10:07 |  #13
Misbehaving IS ? It's supposed to help, not hurt. And it DOES help.
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
TheBurningCrown
May 29, 2010 10:09 |  #14
mitchman wrote in post #10266718 (external link)
You do know that 1/500th is over the sync speed of your camera, right (Unless you're using those newfangled pocketwizard "jump the gate" TT5 triggers ;))?
-Dave
Gear List & Feedback
Shuko
May 29, 2010 10:31 |  #15
How do you press the button? First half way or straight away all the way? IS requires time to "spool up", pictures can be blurred if shutter opens when the IS is still moving the lens.
www.miikajarvinen.fi (external link)
3,217 views & 0 likes for this thread, 16 members have posted to it.
1053 guests, 115 members online
