Thread started 29 May 2010 (Saturday) 15:24
Getting to know the 5Dc
vinunleaded
May 29, 2010 15:24 |  #1
So I slapped on my 580exII. Set it to manual. Flash output is 1/128.
I set my camera to aV mode with 2.8 speed.
For some reason, the shutterspeed is locked to 1/8000. The camera will not adjust the shutterspeed to get the correct exposure. Why?
Canon 5DII + 70-200 2.8 IS L + 580EXII
Canon 5Dc + 24-70 2.8L + 580EXII
Shoreline, WA
http://www.thuanphotog​raphy.com (external link)
http://www.flickr.com/​photos/thuthuan/ (external link)
HaroldC3
Gallery: 69 photos
May 29, 2010 15:52 |  #2
What's your ISO set at?
Flickr (external link) ~ Instagram (external link)
Stuperfox
Gallery: 12 photos
May 29, 2010 16:01 |  #3
In manual mode, the camera does not know what the exposure should be so it just go all the way up to max shutter speed. I assume that you have the high speed sync on, otherwise it will be set to 1/200th max. Put it on TTL and then it will work(but the shutter will expo for ambiante unless you set the custom function to 1/200th fixed). Put it on tv and it will lock at 1/200th max, but anything below that you can use.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
1,103 views & 0 likes for this thread, 3 members have posted to it.
1674 guests, 110 members online
