hey everyone.my alien bee 800 flash tube has this little bubble on it.it looks like it melted a little bit.is that normal?.is it dangerous?
varuj Senior Member 330 posts Joined May 2007 Location: van nuys ca More info | May 29, 2010 18:20 | #1 hey everyone.my alien bee 800 flash tube has this little bubble on it.it looks like it melted a little bit.is that normal?.is it dangerous?
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | May 29, 2010 19:40 | #2 Did you or anyone else by chance physically touch the bulb at any point? Not sure, but I think those bulbs will do that or worse when you get finger grease on them. [Gear List | Flickr
110yd Senior Member 790 posts Likes: 35 Joined Jan 2005 More info | May 29, 2010 19:47 | #3 varuj wrote in post #10268455 hey everyone.my alien bee 800 flash tube has this little bubble on it.it looks like it melted a little bit.is that normal?.is it dangerous? Do you mean the glass or the filament has a bubble? (Neither would be a good thing) A picture would be worth a thousand words.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | May 29, 2010 21:02 | #4 Indeed. Please post a pic, so we can further assess the situation. [Gear List | Flickr
May 30, 2010 02:00 | #5 i think i might have touched it while i was putting modifiers does this look normal?
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | May 30, 2010 05:32 | #6 varuj wrote in post #10269831 i think i might have touched it while i was putting modifiers ![]() does this look normal? If you are referring to the little glass blob on the upper side flash tube to the right of center in the photo above, that is perfectly normal. It is the place where the final seal was made when manufacturing the tube. Skip Douglas
o ok cool.but i dont remember if it being like this when i first got it.
110yd Senior Member 790 posts Likes: 35 Joined Jan 2005 More info | May 30, 2010 18:30 | #8 varuj wrote in post #10268455 hey everyone.my alien bee 800 flash tube has this little bubble on it.it looks like it melted a little bit.is that normal?.is it dangerous? Hello varuj,
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | May 31, 2010 12:56 | #9 SkipD wrote in post #10270181 If you have touched the flash tube, it would be a good idea to clean your fingerprints off. I would probably use a clean paper towel moistened with Windex for the purpose, though I have never gotten fingerprints on my flash tubes. Just make sure you do not disturb the little wires that are outside the flash tube. Windex? Or rubbing alcohol Skip? I was always told rubbing alcohol was best to use for that. Same with headlight bulbs in your car. The higher the alcohol percentage the better in the rubbing alcohol. [Gear List | Flickr
Conner999 Senior Member 748 posts Likes: 1 Joined Apr 2006 Location: Nova Scotia, Canada More info | May 31, 2010 15:14 | #10 Iso alcohol (aka isopropanol) - you can get a 99% or better solution for next to nothing in most drugstores, etc. The idea is to get as pure an alcohol you can use/obtain with, as Ben says, as little, if any, oil or other junk (scents, etc) in it -- any of which will remain on the tube after cleaning in the formula. Use it damp on a paper towel taking care with the trigger wire around the tube and make sure no PT fragments got caught on it. Let air dry and away you go.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | May 31, 2010 17:58 | #11 ben_r_ wrote in post #10276526 Windex? Or rubbing alcohol Skip? I was always told rubbing alcohol was best to use for that. Same with headlight bulbs in your car. The higher the alcohol percentage the better in the rubbing alcohol. A little alcohol would probably do just as well or possibly better than the Windex. The key is to use a solvent that will get the fingerprint off and leave no residue. Skip Douglas
o ok cool then ill just clean it up with some alcohol and just keep an eye on it.thanks a lot guys
| Latest registered member is Mihai Bucur 1179 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
