Thread started 29 May 2010 (Saturday) 20:26
Missing autofocus beam when YN RF-602 is used
coldplug
May 29, 2010 20:26 |  #1
Hello,
the problem: when I use off camera flashes, triggered by YN RF-602 transmitter/receivers, I can't have my speedlite flash mounted on the camera hotshoe, because there is RF-602 transmitter, and thus I don't have autofocus beam from it. The result is being unable to autofocus when no enough light is available.
Is there any solution on the market? Some third party autofocus beam device that will fit between camera and RF-602 transmitter or so?
kaitlyn2004
May 29, 2010 20:32 |  #2
Flashlight?
My Landscape Photography Videos (external link)
My Instagram (external link)
SAPSTAR
May 29, 2010 20:38 |  #3
kaitlyn2004 wrote in post #10268949 (external link)
Flashlight?
I agree. You can use a flashlight. If you have your shutter speed high enough to cut off the ambient, the flashlight will not effect your final image.
coldplug
May 29, 2010 21:29 as a reply to  @ SAPSTAR's post |  #4
Isn't this little bit impractical to use? You mean holding flashlight with hand or some kind of fitting it to camera?
Thx
yanagapa
May 29, 2010 21:33 as a reply to  @ coldplug's post |  #5
Why not manual focus?
Canon XSi | Sigma 18-50/2.8 ex | ef 100/2.8 Macro| ef-s 55-250 IS| 430exII |
www.italiancatering.ca (external link)
coldplug
May 29, 2010 21:38 as a reply to  @ yanagapa's post |  #6
Because there is again no enough light for manual... at least, looking through viewfinder. By using live view it could be possible, but if you taking people photos, this is no solution.
Why Canon does not have autofocus light simply in the body like Nikon :rolleyes:
I found this as major issue. If I mount speedlite on the hotshoe, I cannot use RF-602 anymore. If I use RF-602, I cannot use speedlite assist beam :(
Matt_C
May 29, 2010 23:45 as a reply to  @ coldplug's post |  #7
If your camera supports it hook up the transmitter to the pc sync port and put the flash on the hot shoe.
coldplug
May 30, 2010 03:32 as a reply to  @ Matt_C's post |  #8
40D, it seems it does have it? :) I'll try that option, thx!
kaitlyn2004
May 30, 2010 06:55 |  #9
What I meant about the flashlight was.... illuminate your subject, get focus and lock it/go into MF mode
coldplug
May 30, 2010 16:16 |  #10
kaitlyn2004 wrote in post #10270328 (external link)
Possible only for static subjects. For people this would not work...
SAPSTAR
May 31, 2010 19:46 |  #11
coldplug wrote in post #10269130 (external link)
Thx
Holding the flashlight works for me for the few occasions I need it... If my subject is not static and is moving, I wont be using off camera flash... In that case my external flash unit which is on camera does the job.
ffkk
Jun 01, 2010 00:05 |  #12
Several years ago I used a laser beam to achieve focus lock. It was those you buy at a convenience store. It wasn't the simple red dot laser. This one had several replaceable caps that had different designs. Like an alien, dog, etc... Worked pretty good for me in the past.
Found some links.. I notice they have green lasers now. Dunno how they would work compared to the red. I would probably stay with the low >5mW range.
http://www.amazon.com …00EE77Q2/ref=pd​_sbs_sg_30 (external link)
http://www.amazon.com …000FM19US/ref=p​d_sim_e_44 (external link)
egordon99
Jun 01, 2010 06:54 as a reply to  @ ffkk's post |  #13
Semi-related story...I was shooting folks dancing on a patio at night with NO ambient light aside from the DJ's "strobes/color light stuff"
I was able to bounce my flash off of the white wall of the house but that would mean I would be RIGHT on top of the guests, so I busted out my light-stand/shoot-through umbrella and coupled my 580EXII with my Cactus receiver.
My 24-70L ( on my 40D) could NOT focus AT ALL. My Xsi+10-20 could actually focus pretty decently, even though I couldn't see anything through the viewfinder. I guess the much wider field-of-view of the 10-20 had something to do with it.
All in all, I did get some nice shots in a very challenging situation. Next time I'll bring a flashlight :)
2,263 views & 0 likes for this thread, 7 members have posted to it.
1396 guests, 165 members online
