Recently, beauty dishes are the rage and these days there seems to be as much talk about using diffusion socks as there is talk about using grids. How we shape and control light is a very personal thing and there really is no right or wrong. Putting aside the rules that ensure proper exposure and color, the only real rule in lighting is to create the lighting that appeals most to you and/or your clients.
Having said that, one of the most common questions that comes up in the grid and diffusion sock discussions is whether using the sock and grid together is effective and whether it makes a difference which is closer to the light source and which goes on the outside.
Well, I'm not going to give you an answer. I'm just going to give you some images to compare and then you can make up your own mind as to the quality of light you like.
The first set of images shows how the light falls on the subject from a distance of 33" (1.5x the diameter of the Speedotron 22" beauty dish) and 45 degrees off axis, angled down towards the subject in a 'standard' main light position.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
