philwillmedia wrote in post #10281783
Hi Lisa,
The others I mentioned, the 5D II, 7D or 1D MkIV, are all the top end consumer/pro bodies.
Whether thos bodies are "better" for astro photography, I don't really know, but an educated guess would suggest they would have to be, simply because they are more advanced cameras.
Comparing the 7D and 550D (T2i) specs, for example, the main differences are:
Autofocus-19 points on 7D, 9 points on 550D -not significant for most if any astrophotography purposes
Fastest shutter speed- 1/8000 on 7D, 1/4000 on 550D - not significant for most if any astrophotography purposes.
Viewfinder - pentaprism with 100% frame coverage on 7D, pentamirror with 95% frame coverage on 550D - little if any significance for most astrophotography purposes.
Burst mode - 8 fps for 7D, 3.7 fps for 550D - not significant for astrophotography
Body material - magnesium allow, weather resistant for 7D, stainless steel and polycarbonate resin with glass fiber, less weather resistant for 550D - could be significant if you bang it around or drop it or get caught out in the rain.
Weight - 820 gm (1.8 lbs) for 7D, 530 gm (1.17 lb) for 550D - advantage to the 550D for astrophotography.
Battery - 1800mAh for 7D, 1250mAh for 550D- advantage to the 7D
ISO setting - 1/3 stop for 7D, full stop for 550D - perhaps a slight advantage for the 7D
Image processor - Dual Digic 4 for 7D, single Digic 4 for 550D - not significant for astrophotography purposes.
Shutter life - 150,000 cycles for 7D, ~ 100,000 cycles (?) for 550D
These two cameras are from the same generation and have the same sensor and image processor, though the 7D has dual processors, which makes it faster, but not better. Image quality for the same lens at the same exposure settings should be identical.
The greatest advantage of the 7D for astrophotography is probably the battery life, but this advantage can be negated by carrying multiple batteries or using an optional battery grip or AC adapter. The greatest disadvantage of the 7D is probably the weight - this could be a show-stopper, depending on the telescope and mount. Along with the additional weight of the 7D comes added durability, which should be considered if you're rough on your cameras.
The predicted shutter life takes on tremendous significance when your shutter fails. But you could buy two 550D's for the price of a 7D and gain the advantage in this category.
Don
