Thread started 31 May 2010 (Monday) 13:43
Not for arachnophobes!
naddieuk
May 31, 2010 13:43 |  #1
I happened to see this on my bedroom wall. I was quite a distance away and the flash seemed to have stunned it a bit. Managed to get it removed.
Any ideas on the type of spider? It was about 5cm long. As it was very late night and I was very sleepy, I had it on the Macro setting and thus the flash was fired and it was on 55mm.
Exif Data:
EXIF Sub IFD
* Exposure Time (1 / Shutter Speed) = 1/60 second ===> 0.01667 second
* Lens F-Number / F-Stop = 56/10 ===> ƒ/5.6
* Exposure Program = n/a (0)
* ISO Speed Ratings = 400
* EXIF Version = 0221
* Original Date/Time = 2010:05:29 23:55:32
* Digitization Date/Time = 2010:05:29 23:55:32
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Shutter Speed Value (APEX) = 387114/65536
Shutter Speed (Exposure Time) = 1/60 second
* Aperture Value (APEX) = 325770/65536
Aperture = ƒ/5.6
* Exposure Bias (EV) = 0/2 ===> 0
* Metering Mode = pattern / multi-segment (5)
* Flash = Flash fired, auto mode
* Focal Length = 55/1 mm ===> 55 mm
* User Comment (Hex) = User Comment Character Code = not defined
* FlashPix Version = 0100
* Colour Space = sRGB (1)
* Image Width = 3456 pixels
* Image Height = 2304 pixels
* Focal Plane X-Resolution = 3456000/874 ===> 3954.23
* Focal Plane Y-Resolution = 2304000/582 ===> 3958.76
* Focal Plane X/Y-Resolution Unit = inch (2)
* Custom Rendered = normal process (0)
* Exposure Mode = auto exposure (0)
* White Balance = auto (0)
* Scene Capture Type = standard (0)
Canon Powershot S95, Canon EOS 1000D attached to Skywatcher Explorer 150P on an EQ-3 unguided mount.
My Flickr site. (external link)
canonloader
Gallery: 6 photos
May 31, 2010 15:35 |  #2
You should post it in the Macro forum, those guys know spiders. :)
Mitch- ____...^.^...____
pttenn
Jun 01, 2010 12:51 |  #3
If you could use fill flash to lighten up the back, might be able to see more detail. Has the general shape of a brown recluse. :(
Karen
MyLookingGlassEye
Jun 01, 2010 18:14 |  #4
Sorry, there's not enough detail and WAY too many spiders of that general shape/colour for me to make an accurate ID.
My PhotoCenter :D :
Gripped 12DD2 ;)/5 bits of glass/dual triple tubes/Sig TCs,
2-580EXIIs/Manfrotto 055CXPRO3 with 3 heads/Cool-lights/Soft box/reflectors/ExpoDis​c & filters galore/Epson R1900+CISS/Now CS5 powered! :p
Adam ­ Jones
Jun 01, 2010 18:43 |  #5
pttenn wrote in post #10282705 (external link)
Karen
Yikes!
Anthony | Flickr (external link) | Blog (external link) | www.purplecollarphoto.​com (external link)
naddieuk
Jun 02, 2010 01:15 as a reply to  @ Adam Jones's post |  #6
Hi,
Thanks for all the replies. This was a spider in the UK and thus is luckily not a brown recluse. I sure hope I never see another one like it in my bedroom again, so the chances of a better photo is rather reduced! ;)
In the Macro threads, I have been told that the spider is most likely to be either a sac spider or a woodlouse spider, and as has been pointed out here, the photo quality is not good enough to tell. I have not been able to tell from the photos on the Internet as it has been making me rather itchy and uncomfortable looking at photos of spiders! Sorry. :oops:
It has shocked many of my friends who I emailed the photo to as it makes it look even more scary!
Edit:
Sorry, I forgot to mention that the reason it does not look so good is that the lighting in my bedroom is rather dim and thus the flash came on, also it was coming up to midnight when I took the photo; I was not going to try and use the aperture priority, as my main concern was sleep :D
Edit 2:
I also think it is a woodlouse spider, I just did an image search on Google and the second image on Britannica seemed to look the same. They have a painful bite!
Disturbed ­ UTT
Jun 02, 2010 04:54 |  #7
naddieuk wrote in post #10286693 (external link)
Edit 2:
Spider in UK with a painful bite???? Oh great :(
And why when it says in the title "Not for arachnophobes" did I still have to have a look.
Canon EOS 5D III | Canon EOS 7D | Canon EOS 400D Gripped
Canon EF 70-200mm f/2.8 III L IS USM | Canon EF-S 17-55 IS F/2.8 | Canon 50mm F1.8 mk1 | Canon 100mm F/2.8 Macro | Canon 70-200 F/4 L USM (non IS) | Canon EF 100-400mm f/4.5-5.6 L IS USM
Canon 430ex II & 580ex II
naddieuk
Jun 02, 2010 06:53 as a reply to  @ Disturbed UTT's post |  #8
I wrote that title, just in case there is someone that doesn't like spiders. They can skip this thread without worrying. I guess it's the "Wet Paint" mentality many of us have!
Disturbed ­ UTT
Jun 02, 2010 07:43 |  #9
I was going to mention the wet paint as well :D
I don't really mind them that much.
1,898 views & 0 likes for this thread, 6 members have posted to it.
1369 guests, 188 members online
