Thread started 01 Jun 2010 (Tuesday) 09:54
HELP NEEDED: Pocket Wizard problem -> 2 x TT5 are not 'synching'
Cham_001
Jun 01, 2010 09:54 |  #1
Hi all..... :)
Ok, I am now back in London, and for some reason my 2 x Pocket Wizard TT5s are nolonger synchronising. I do travel with all my Manuals and I have done the following:
I have tried to Teach/Learn the TT5's according to the Instruction Manual
Transmitting TT5 = LEFT // Receiving TT5 = RIGHT
1.> Keeping the TT5's apart by at least 2 ft - I do this at a min of 4ft
2.> LEFT Test/Learn button is depressed until the 'amber' LEDs flash
3.> I release LEFT - and with RIGHT in my Hand I quickly depress Test/Learn until it goes through the LED flashing sequence, however the GREEN LEDs do not flash or blink - which means the Channel has NOT been learned.
I have done this on numerous occasions, I have also Reset both TT5 to default-factory settings and proceeded with the TEST/LEARN sequence.
I have also tried these sequences on Channels 1 & 2 on both TT5s.
One thing I have noticed is that once I complete a Test/Learn sequence, when I depress the Test/Learn button to check whether the units have synchronised - the receiving TT5 LED flashes RED. So, I guess they are communicating OK, but they are not synchronising.
According to Page 9 of the Manual this is normal. However, the attached 580exII will not fire, either via Test triggering or via a TT5 mounted on the Hotshoe.
Any advice/assistance/guid​ance/help/suggestions will be greatly welcomed as I have exhausted my knowledge-base.
Thanks in advance....... :cry:
"... with a clear perspective - the confusion is clearer ..."
Body: < changing >
Lenses: 70-200mm f/2.8L IS II USM, 24-70mm f/2.8L II USM
Flashguns: 580ex II x 4, MT24 macro flash
Accessories: Pkt Wiz TT5 x 5, AC3 x 2, MiniTT1 x 2, Sekonic L-758DR
Studio Lights: Godox ADpro x 3
jacuff
Jun 01, 2010 10:15 |  #2
Ok, so your in London trying to use FCC/US PocketWizards (340.00 to 354.00 MHz)? The EU limits the frequency to the 433.62 - 434.22 MHz range. Assuming you aren't mixing CE and FCC versions, there is also a possibility of frequency interference.
Do you have a laptop/netbook available that has the PocketWizard utility? You could plug both of them up and set them to the same channels.
Gear, Feedback (eBay (external link)), Web (external link), Blog (external link), FB (external link), Twitter (external link)
souporman
UK SE Photographer of the Year 2011
Jun 01, 2010 10:24 |  #3
jacuff wrote in post #10281858 (external link)
I don't know about the other details, but I have US versions of the PW Plus2's and use them all the time over here without any problems. You can probably strike that from your list of possible issues.
http://www.evilkitchen​.ca (external link) (365 (external link)) .
500px (external link)
Twitter (external link)http://365.evilkitchen​.ca (external link)
Cham_001
Jun 01, 2010 10:24 |  #4
I should have said, these 2 x TT5's are both UK/CE spec bought from Calumet in London, Euston early this year in March/April 2010.
Body: < changing >
souporman
Jun 01, 2010 10:25 |  #5
Cham_001 wrote in post #10281902 (external link)
You can definitely strike that from your list of possible issues then :)
tenoverthenose
Jun 01, 2010 10:31 |  #6
I have generally found that putting fresh batteries in my PW Flex/Mini solves 90% of all problems.
www.patrickpike.com (external link) | twitter (external link) | facebook (external link)
Cham_001
Jun 01, 2010 10:54 |  #7
tenoverthenose wrote in post #10281945 (external link)
Hi Patrick,
Yep, I tried that too - despite the LEDs blinking GREEN with the original batteries (GREEN indicates good battery life)..... :(
Body: < changing >
Lichtwerk
Jun 01, 2010 22:50 |  #8
Try this. Also see if they both have the current firmware. A lot of problems with the TT5's can easily be avoided by making sure both run exactly the same firmware version (and preferrably the latest of course).
Dennis
Grip Aficionado
Cham_001
Jun 02, 2010 00:52 |  #9
Lichtwerk wrote in post #10286040 (external link)
Yep, both are running identical versions of the version 5.000 software.
(Prior to Posting - I also set them to the Same channel too!)
It is very strange - they were working perfectly well about 4 days previously, and now this!
I had not dropped them
I had not reset anything
I had not changed anything
I simply set up all the required kit yesterday at mid-day and have met with a wall of frustration.
Most bizarre!
Body: < changing >
CxThree
Jun 02, 2010 07:25 |  #10
How far apart are the PWs? I got sort of upset one day when mine would not fire, but I was just testing them at my desk. I found that when they are really close together, they do not provide good results.
Canon EOS 5D MKIII, 7D
Canon Lenses : 70-200 F2.8L II IS : 24-105 F4L IS : 16-35 F2.8L : 50mm F1.4 : 85mm F1.8 : 100mm F2.8 Macro : 10-22mm
4x 600EX-RT
Speedotron Black Line
Cham_001
Jun 02, 2010 08:24 |  #11
CxThree wrote in post #10287586 (external link)
Well initially, I had been 'synching' these at arms-lenth apart, in the one room.
So, say 2ft+1ft+2ft (one in each hand, across my body) = 5ft
Then I asked a family volunteer to wander off at a distance of say, 12-15ft and tried 'synching' them across 2 rooms - again unsuccessfully!
(When I first bought and 'synched' them - it happened very quickly and very easily). I have since tried again today a couple of times and still no success. :cry:
Body: < changing >
jacuff
Jun 02, 2010 09:02 |  #12
Know anybody with a 550EX flash or do you have some strobes you can use as the light source? In the US, the 580EXII is known to cause interference resulting in lower range, but that's not usually an issue at 15 feet away. Doing the factory reset on all units and setting them to C1 should make them fire in sync. Your flash isn't in slave or master mode is it? Short of checking those settings, you may have a faulty unit that needs to be serviced.
Cham_001
Jun 02, 2010 14:21 |  #13
jacuff wrote in post #10288019 (external link)
The 580ex is in neither master/slave mode, also the flash-head is set to fire! I previously reset both TT5's and tried again, I also used my laptop to 'synch' to C1. The 580ex has also been reset so that the default settings have been restored. The Custom Functions menu on the flashgun has also been restored.
At the moment nobody over here as all of my friends in he UK shoot with Nikon systems. I do have an MT24 that has been borrowed, it should be returned later this week - certainly before Sunday. I may just have to wait until then.
In the meantime I can always go through all the setings and reset to factory-default. As this has already been done - I have time to repeat this!
I will be very disappointed if this 580exII needs 'burying' as it has not even reached 1,000 activations. I recently 'dumped' my EF 28-135mm - hopefully the cause is not contagious!
If the 580exII is broken then "....C'est la vie...."
Body: < changing >
jacuff
Jun 02, 2010 14:32 |  #14
Cham_001 wrote in post #10289938 (external link)
Does the 580EXII fire when it is mounted in the hotshoe of a camera?
Cham_001
Jun 02, 2010 16:12 |  #15
jacuff wrote in post #10290008 (external link)
Hi Jacuff,
Yes, I tried this and it works fine when mounted directly.
It just does not fire when used with the TT5's.
I also tried attaching a single TT5 to the camera hotshoe, then I attached yje 580exII to the TT5. This also worked.
I am just looking at all this gear and thinking - WHY?
(other thoughts have also crossed my mind like WTF?)
I feel that the onset of baldness would not be inappropriate at this stage - I am really totally baffled!
Body: < changing >
5,517 views & 0 likes for this thread, 8 members have posted to it.
1513 guests, 131 members online
