I just got these programs with my T1i last week. I've been concentrating on the camera, and now I'm going to start learning the software.
The problem I've had is that Dpp and Picture Style Editor won't run unless I set my windows Vista Color depth to 16bit. If I try to start either program while running my computer normally, I get the error window, "this program requires a display capable of 1024x768 resolution or more (screen area) and High Color or higher
settings." Since my display is set at 1600x900 (LG 21" LCD monitor) and Highest (32bit) color, this shouldn't be a problem.
I contacted Canon Support, they're the one who told me to set my display to 16 bit. When I asked if this was a bug and when would it be fixed, I got the following response:
There aren't any bugs regarding this particular issue. The software will not install or run if the screen resolution is not properly set. This will make all of the software compatible with Vista.
BTW, I've updated all the programs with the latest updates from Canon, hoping that would solve the problem, before I contacted Canon support.
Any of you have to do this? Isn't lowering the color depth going to affect the quality of the pictures being edited?
Thanks for any insight;
Scott
