For those of you out there who have tried both the Luma Loop Labs and Black Rapid R camera straps,which between the two do you personally preffer?And why?
Thanks.
NoOne Senior Member 372 posts Joined Oct 2007 Location: Philippines More info | Jun 03, 2010 09:15 | #1 For those of you out there who have tried both the Luma Loop Labs and Black Rapid R camera straps,which between the two do you personally preffer?And why?
kinghong1970 Goldmember 2,093 posts Likes: 3 Joined Jun 2009 Location: NYC/NJ More info | Jun 03, 2010 09:23 | #2 i have both... Albert the Clumsy Ape
Fstop-Ian Senior Member 329 posts Joined May 2009 More info | Jun 03, 2010 19:48 | #3 You may find your answers in this thread -https://photography-on-the.net/forum/showthread.php?t=858917 If you have support related questions regarding F-Stop Gear, please email an@fstopgear.com
EcoRick Goldmember 1,863 posts Likes: 1 Joined Nov 2006 Location: Chicago, IL More info | Jun 04, 2010 06:59 | #4 kinghong1970 wrote in post #10294904 I am a bit concerned about the BR metal carabiner coming in contact with camera I put gaffers tape on the bottom of my camera just in case the carabiner rubs against it. Gear: Canon 1Ds MkII, 35L, 85L, 135L, 24-105L
lannes Goldmember 4,370 posts Likes: 8 Joined Dec 2009 Location: Perth, Australia More info | Jun 04, 2010 08:17 | #5 EcoRick wrote in post #10300872 I put gaffers tape on the bottom of my camera just in case the carabiner rubs against it. I found the knurled ring on the ConnectR-2 was scratching the camera body, so I used some heat shirnk tubing to cover the offending parts. 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
r.kristoffersen Member 37 posts Joined Jan 2010 More info | I have both the BR-5 and the LL. The reason I decided to order the LL as well was because that I find the BR-5 for some situations a bit bulky and that the BR-5 is connected to the podmount. You´ll have to unscrew the podmount when using a tripod, which some find to be a hassle. The LL is more discrete (smaller shoulderpad) and you can fasten the LL to almost any part of the camera body you desire.
| Latest registered member was a spammer, and banned as such! 2742 guests, 146 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
