That can hold two slrs, two flash guns, six to seven lenses max budget £150
RichSoansPhotos Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 04, 2010 10:37 | #1 Permanent banThat can hold two slrs, two flash guns, six to seven lenses max budget £150
gonzogolf dumb remark memorialized More info | Jun 04, 2010 10:38 | #2 Depends on which 7 lenses you mean.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jun 04, 2010 10:40 | #3 What all are the lenses you want it to hold? None of your current crop are all that big, but you're obviously planning on adding 3-4 others. And do you want the bodies to be gripped or ungripped? Jon
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 04, 2010 10:52 | #4 Permanent banSorry, the signature has a limit, I have an 85mm f/1.8 USM and currently thinking of getting the 10-22mm UWA and 24-105mm L USM f/4, hence the need for space, can easily forget the kit lens
gonzogolf dumb remark memorialized More info | Jun 04, 2010 10:53 | #5 If you want backpack style the lowepro trekker or computrekker should do that.
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 04, 2010 10:56 | #6 Permanent banoops got a macro on the way, though I could double it with the 50mm f/1.8 MkII
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 04, 2010 11:13 | #7 Permanent banThe only problem with that bag, if I go on holiday, I am told it is heavy and airliners won't allow me to check it in, gonzogolf
gonzogolf dumb remark memorialized More info | Jun 04, 2010 11:29 | #8 400dabuser wrote in post #10302027 The only problem with that bag, if I go on holiday, I am told it is heavy and airliners won't allow me to check it in, gonzogolf you want it hold all that and still be small and light? Sorry thats all I got.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jun 04, 2010 11:36 | #9 Depends on the airline. You might not find them too easy to locate over there, but I'd suggest a Domke F1x or F2. Shoulder bags, not very heavy of themselves (under 1 Kg) but you can easily load them so full Virgin or Ryanair will hit you with a carry-on surcharge, or just not let you take them. I'd suggest getting a traveling companion who can carry some of your gear if you need to take an airline like that. Jon
JoeRavenstein Goldmember 2,338 posts Likes: 1 Joined Mar 2010 Location: E Tx More info | Jun 04, 2010 11:47 | #10 The Lowepro 400AW magnum will hold your gear and is an over the shoulder bag and is sized for carry on size limitations. Lowepro indicates whether a bag is sized for aircraft carry on in their catalog. That being said I was just reading a post in this forum where the weight limits varied for carry on and I'm fairly sure mine wouldn't be allowed with my gear as is. That individual had to pull cameras and lens to meet the weight restrictions, and carry them slung around his neck and in pockets Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
RichSoansPhotos THREAD STARTER Cream of the Crop 5,981 posts Likes: 44 Joined Aug 2007 Location: London, UK More info | Jun 09, 2010 15:08 | #11 Permanent banJoe Ravenstein wrote in post #10302196 The Lowepro 400AW magnum will hold your gear and is an over the shoulder bag and is sized for carry on size limitations. Lowepro indicates whether a bag is sized for aircraft carry on in their catalog. That being said I was just reading a post in this forum where the weight limits varied for carry on and I'm fairly sure mine wouldn't be allowed with my gear as is. That individual had to pull cameras and lens to meet the weight restrictions, and carry them slung around his neck and in pockets
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jun 09, 2010 19:14 | #12 Yeah - but once you're past the guardians of the gate, everything goes back into the carryon you took it from. Jon
111t Senior Member 577 posts Joined Apr 2009 More info | Jun 09, 2010 19:17 | #13 Tamrac ultra pro 13... When you absolutely positively need to carry everything you've got... Gripped!http://www.calumetphoto.com …a=CA01&CAWELAID=337065370 All The best!
| Latest registered member was a spammer, and banned as such! 2946 guests, 157 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
