Thread started 04 Jun 2010 (Friday) 16:01
Rotated Front Element on Canon 28-300 lens
bmitch
Jun 04, 2010 16:01 |  #1
OK, so I have what I think is a unique problem.
The front front ring that the lens hood mounts to on my Canon 28-300 lens has rotated and now when I attach the lens hood at certain focal lengths the hood shows up in the pictures.
Does anybody know if it is a simple procedure to realign that ring?
Thanks,
Mitch
Canon 5D Mark III, Canon EF 28-300mm f/3.5-5.6L IS USM, 580EX II
Canon 5d Mark II, Canon 70-200 f2.8 IS II USM, Canon 17-40mm f4L USM, 50mm f/1.8 II, 430EX
http://www.brishanphot​ography.com (external link)
katodog
Jun 04, 2010 16:08 |  #2
I'm trying to remember if the front element was individual on the lens, and the little screws in the ring are all that's holding it. I think they are, and if so you can loosen them a little, turn the ring to where it belongs, and re-tighten the screws.
In other words, the silver band with the "Canon Zoom Lens EF....", there's three or four screws in it. Loosen them, turn the whole front element, ring and all, to where they need to be, then tighten the screws. It's possible the screws are already loose, and that's why the front element moved. Wish I could help further, but I sold mine months ago, and can't recall how many screws there are.
Typically the front element in in its own cell, and you can take it off and put it on with no issues. Sometimes they need to be in the correct position for the best IQ, but I doubt it with that lens. Just loosen the screws a bit and see if the whole front cell moves, if it does you're all set.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
philwillmedia
Jun 04, 2010 16:35 |  #3
You've probably already checked, but are you sure that the hood is mounted properly and locked in place?
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
bmitch
Jun 04, 2010 19:53 |  #4
Thanks katodog, we're thinking of giving that a shot. Just one of those things you have to just hold your breath and do it! LOL
Phil, we checked that, but that is a good question.
katodog
Jun 04, 2010 20:01 |  #5
If I remember correctly, the hood only goes on two ways, right side up and upside down. I don't think you can put it on sideways. If that makes any sense. I think the only way it could be on "wrong" is if the front element did turn, which is probably because those screws are loose, or were loose.
Try it and see, the worse that can happen is the element comes off, which is no big deal because that whole cell is just screwed on in the first place. And you don't have worry about it being "right", because the front element of a camera lens is just a basic optic, there's no right or wrong way for it to go on. Besides, all you're going to do is turn it a little bit.
Here's an image of the one I had, maybe it'll help figure out which side is "up" if you turn it...
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i15.photobucket​.com …028-300mm/28-300mm001.jpg (external link)
criza
Joined Apr 2011
Apr 13, 2011 08:20 as a reply to  @ katodog's post |  #6
Hey!
I've got a problem with this lens. I removed the two screws at the end of the front part of this lens (where you fix the lens after you set the focus), unfortunately I can't screw them back. As it seems the little balls in the ball-bearing have moved and now you can't turn the the holes of the outside part to the point where the holes on the back, down part of the lens are, so you could turn the two screws back in place. I know this is not good English and my problem is a very stupid one! Still, is it a big thing to take the lens apart, in two pieces, but the ball-bearing balls back to their place and then rotate the lens back so the outer holes and inner holes match, so you can put back the screws? If anyone could point this out, I would appreciate it very much! Thank you.
Chris
2,882 views & 0 likes for this thread
Latest registered member is michaelscheuren
772 guests, 170 members online
