Thread started 06 Jun 2010 (Sunday) 22:32
580EX2 and 420EX compatability 5dmkii sync
nzav
Joined Jun 2010
Jun 06, 2010 22:32 |  #1
Hi. I have a 5d mkii, 580EX2 and a 420EX which I only just received. I can master the 580EX2 on the hotshoe and slave the 420 but when I connect the 580EX2 via a sync cord I cant fire the 420... is this corrector am I doing something wrong?
And what flash do I need in order to achieve this if the 420 will not comply.
Thank yoiu
SilverHCIC
Location: Swimming, cycling or running ... somewhere in California
Jun 06, 2010 23:08 |  #2
First, welcome to the forum!
As far as using the 580 off-camera as a master, a Canon-compatible ETTL cord will allow full functionality (including allowing the 580 to function in master mode). If your sync cord is just a trigger-sync, it will not work. You can get a very good ETTL cord from Flash Zebra.
"It's easy to find your bike in transition when you're the last one out of the ocean ... it's no fun being lost at sea :rolleyes:."
nzav
Joined Jun 2010
Jun 06, 2010 23:10 |  #3
Thank You. I
Aha I was not aware i needed an ettl cord. Perfect. Cheers for the answer. Thats an easy solution
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Jun 06, 2010 23:25 |  #4
Canon disables the 580EXII's PC port when it is in Master and Manual modes.
A hybrid triggering can be done by connecting a PC-sync cord to an adapter foot. A radio trigger can also be used. The 580EXII is placed on the adapter and set to Master and Manual.
A Speedlite slave can then be set manually. It is fired by Canon Wireless.
But, I think that the 420EX cannot be set manually.
The hybrid triggering does not use ETTL.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Jun 30, 2011 16:23 |  #5
CliveyBoy wrote in post #10315483 (external link)
Did you mean Master and Slave?
Image Editing OK
dedsen
Jun 30, 2011 16:50 |  #6
I think he means what he says. That is what i have been trying to explain to you in the other thread. When the 580ex is in master mode it can also be switched between eTTL and manual modes. Two different options selected in two different menus.
digital ­ paradise
Gallery: 157 photos
Jun 30, 2011 17:15 |  #7
Oh I see. Sorry about that.
Image Editing OK
ukcyberboy
Jul 01, 2011 06:16 |  #8
dedsen wrote in post #12684878 (external link)
Dale I havent used that function yet on my flash, where would I be able to set it up on my 580exii
Body | Canon 6D |
Lens | Yongnuo 50mm 1.8 |
Lens | Canon 28-70 2.8 L |
Lens | Canon 70-200is F4 L |
Lighting | Yongnuo YN600RX |
Accessories | Various Bits |​
digital ­ paradise
Gallery: 157 photos
Jul 01, 2011 07:18 |  #9
Hold down the Zoom button for a few seconds then flashing OFF will appear. Turn the wheel to get to master or slave. Press middle button to accept. Change you modes - ETTL, Manual, Multi as usual.
Image Editing OK
ukcyberboy
Jul 01, 2011 07:27 as a reply to  @ digital paradise's post |  #10
Thanks will look at that.
Body | Canon 6D |
1,752 views & 0 likes for this thread, 6 members have posted to it.
2768 guests, 174 members online
